Originally posted by Class A Are you talking about the difference between making adjustments to the white point in a pre-phase of the calibration using monitor hardware controls versus skipping that phase?
In any event, either you allow the calibration software to influence the white point or you don't.
Right. I am essentially talking about skipping the adjustments to the white point pre-calibration. I think in the case of one of my monitors, the software has to make more adjustments if I try to adjust the white point prior to calibration. Honestly, it isn't a great monitor, and I don't use it for editing; I mostly throw the library over on that monitor (i.e. thumbnails for browsing).
Either way, the calibration software does make its own adjustments in the calibration phase itself, and everything pretty much comes out right in the end. For instance, an image in photoshop, straddling the two monitors will be consistent across the two. Of course, how off you are at different stages and how much calibration is needed can impact things significantly, but I've not seen problems through links like you provided and prints (which worry me most).
For my own personal needs, I have bigger problems with my eyes than the fact my monitor may be off from perfect by 0.01%.
