Originally posted by kaseki Thanks. I assume this is Wine [NOT] emulating 32-bit Windows within 64-bit Ubuntu. K1N8, which version of Windows were you running in Wine?
Has this been tested with high resolution PEF files? I would worry that 32-bit Windows might not be able to handle large data sets. Maybe only a few photos at a time. I've long forgotten what the real 32-bit limitations are (relative to just calculating 2^32), having dropped Win2k when support ended and moved to Ubuntu at that time.
I actually have the CD.
---------- Post added 25th Mar 2019 at 23:49 ----------
I think you might have to put them within a code block, viz., the #-denoted icon in the lower editor option collection.
it didn't like the cat command I was using to show the redhat-release file. I don't know why
full details (I use playonlinux here to keep it within a gui, the command instructions is what K1N8 says, to use the WINEPREFIX env):
Quote: Code:
Linux 1701d 5.0.3-200.fc29.x86_64 #1 SMP Tue Mar 19 15:07:58 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
install wine
Code:
sudo dnf install wine.i686 wine.x86_64 winetricks playonlinux
this is the version installed
Quote: run winetricks once so it sets up the winetricks directory structure in your home directory
in a terminal type
and then close the window once it pops up.
in playonlinux create a new 32-bit installation directory, I call it DCU but call it whatever you want.
in a terminal, we want to create a softlink between the playonlinux wineprefix and winetricks
Code:
ln -s ~/PlayOnLinux\'s\ virtual\ drives/DCU ~/.local/share/wineprefixes/DCU
now run winetricks again, so in a terminal type
when the window pops up, select DCU, then select windows components, and install DotNET 4.72 and wmp10
it will take a while and have a few prompts.
now download DCU5 from Pentax website, and unzip to a folder; I used ~/Downloads/DCU5
once that is done, go back to playonlinux and click configure for your DCU install prefix, and go to the wine tab and choose winecfg
in winecfg, go to the Drives tab and add a new drive, like E: and in path put in where you extracted the install files for DCU5; click show advanced and under Label put in the label that makes the installer think you have the original CD (mods please edit to add in label if ok to provide)
change the Type to Local hard disk and click OK
Back in playonlinux, go back to the configure window (it should still be open so look for the window in your task list, or reopen by clicking configure) and go to the Miscellaneous tab and choose "Run a .exe file in this virtual drive" and select updater32.exe from your extracted DCU folder. It should install without a hitch.
Go back to playonlinux and in the configure window for DCU in the general tab (first tab) click on "Make a New Shortcut from this virtual drive" and it will search and find Digital Camera Utility. Click on it and click ok, then cancel when it prompts you again. Now it should show up in playonlinux. Simply click run and you should be up and running.
edit: it works with 500 K1 PEFs in a single folder. I haven't tried more, but probably would be smart to keep it under 1000. See screenshots, made some adjustments, everything was working fine, if a bit slower.
