Some prototype result after framing. The size of the initial test prints was reduced to allow adding a white mat and fitting with the already made frame. I've learn quite a bit by printing, making the frame and the assembly, so the result isn't perfect by I'm already quite happy. Next time I'll improve over what I've learned from the forum discussion and doing the craft.
Components used: > Photo: Chiesa San Giorgio Maggiore photo captured in Venice, Pentax K1 and D-FA24-70 on tripod / IR remote, with a bit of burning and dodging to reduce a bit the dynamic range for inkjet printing, especially for the upper edge of the image when the printer may produce banding for near white tones. Printed on Hahnemuhle Baryta paper 325gsm, 60 x 80cm.
> Frame:
- 4 meters of canvas frame wood beams 10x45mm and 4 meters of additional 10x30mm for the back side of the frame.
- Box of 12mm and 16mm screw.
- Sandpaper and steel wool to smooth out the wood of the frame before painting
- 375mm wood pain lack mat finish for painting the raw wood frame to make the wide of the mat frame and b&w print pop more.
> Mounting of the print:
- Wood glue for the frame and wet mounting of the photo on the back board
- 2 units of 1.5mm MICA Finish card board paper sheet 70 x 100cm (1 unit for making the mat frame, and 1 unit for wet mounting of the print)
- 1 units of 0.85mm Hellweiss Hahnemule paper 70 x 100 cm for the mat frame (glue the whole sheet of paper on MICA card board sheet, then cutting the mat frame into it, cheaper than buying a 2mm mat paper)
- 1 units of 5mm foam board for backing of the print mounted on the backboard
- 1 unit of 3mm thick acrylic glass (plexiglass) at the front of the mat frame
(foam board and plexiglas where used instead of MDF and glass to reduce weight of the assembly)
- 150mm diameter PVC pipe normally used for toilets, used to deposit the print without creating air bubbles between the print and the mount board, and laminate the print after gluing to make it perfectly flat.
- 8 units spring clips to press the backboard edges at the back of the frame.
