With all due respect, it sounds like a load of marketing nonsense.
Most TVs come with a contrast rating. DR is basically determine day the contrast ratio. SO a bright sunny day presents a contrast ratio of 20,000:1.
Quote: HDR in a camera is an attempt to extend the dynamic range being captured by under and over exposing parts of the image then shrinking the additional contrast captured into a range that can be displayed.
HDR in a TV is the contrast (and some would argue colour depth, although colour depth is certainly debatable. You can have a black and white squares in a display with HDR contrast the ratio of the brightest to the darkest part of the of the image, with just black and white, no colour depth needed, so that's certainly a red herring.)
HDR TV s for stills are completely misleading. TVs rate their ratios on dynamic dynamic ranges. They turn their illuminating pixels brighter and darker depending on the scene, then compare the darkest one can get with the LCDs at their darkest setting with the to the brightest, with the LCDs turned up to their brightest setting, and those setting change as the TV scene changes, but that's irrelevant to a still shooter, for whom the scene doesn't change.
My advice would be take you HDR images into a store , plug in your memory stick and see which one you like best. Trying to sort through the marketing literature is not going to provide you with useful information. Most of the time you won't even know what they are talking about.
For still, the best HDR image will be the one with the best static dynamic range. Most manufacturers won't provide that information accurately. Trust your eyes.
Essentially on a bright sunny day the contrast ratio is 20,000:1, you camera shrinks that to maybe 500:1,tops, a TV with good dynamic range, the number I've seen floated theoretically is 4,000:1. A newspaper image will be 60:1 and a magazine photo will be 120:1. Some plasma TVs are supposed to be capable of 4,000,000 to one, but that would require being brighter than the sun to be meaningful. Call me sceptical.
The main thing is HDR capture in a camera is an input device. HDR in a TV is an output device. They are completely different classes of devices and not directly comparable. To best display your HDR images (or any still image) you want the TV with the highest static Contrast ratio.
Your camera reduces a 17 EV scene to 14 EV. A really high contrast TV might be able to get it back up to the 17 EV original scene with a perfect display, but as far as i know there is nothing that comes close. That being said, I'm pretty sure your eye can't handle that. We compensate for the lack of ability to resolve high contrast scenes by staring into the light and dark areas of the scene and having our brain stick the scene together. (Kind of like a cameras HDR.) The idea with prints has always been to reduce the contrast to what the eye can actually handle, so finding a TV that would output more than the eye can handle in one pass is pretty much counter productive. And if memory serves me well, what the eye can handle (non-dynamicly) is considerably less than the 14EV a camera can handle. It's actually necessary to reduce the scene's contrast ratio to a more comfortable, less eye strain producing level for comfortable viewing.
