Originally posted by thepedant I use DigiKam on my Linux workstation to hold all my photos. In DigiKam settings there is a checkbox 'Enable Colour Management' and a box to specify a 'Monitor profile'. I looked on the CD that came with the monitor and found a file named HP_24ea.icm which I guessed was what was wanted. I copied the file on to my hard disk, pointed 'Monitor profile' to it and ticked the check box. Is that all I need to do? Or do I still need to get one of those 'Spyder' profiling kits? Is the purpose of the Spyder gadget just to create an .icm file for those monitors that don't already have one? Or is it more complicated than that?
Thanks
A monitor profile is a document that describes the state of your monitor at the time of the calibration against a known standard (usually) that you have specified. Any profile supplied with your monitor will not describe the state of your monitor how could it as your conditions have not yet been imposed.
Should you require an accurate view of your image data for instance to match print to screen then your monitor should be calibrated and this can only be done accurately with a calibration device either Spyder or my pref. X -Rite products
The actual process briefly requires you to specify your target points e.g. D65, etc. Using the calibration device information to adjust your monitor to get as close as possible to those target figures either by manual adjustment or the better way if supported direct writing to monitor LUT. Once all the colour values have been read by the calibration device an ICC profile is produced which accurately describes how your monitor performs against the required aim points.
With this profile colour savvy applications such as Photoshop and Lightroom will display your data accurately and even adjust for display to account for shortfalls in reaching your target values. Non colour savvy apps will not be able to adjust for display inaccuracy. Where DigiKam fits into this and colour accuracy I do not know
This calibration regime will need to be undertaken on a regular basis as monitor values will shift and need to be recorded in a new profile weekly, bi weekly or monthly it will depend but certainly should be done prior to any colour critical work.
Do you need such a device at this time - depends on your needs for printing and others viewing your images.
