Originally posted by innershell What can you do to ensure that screen and print are exactly the same? I got some pictures printed the other day and they were all overly yellow compared to what's on screen. I've never messed around with color spaces before and I don't pretend to know it either.
Well, it's easier said than done. First you need to calibrate your monitor. This usually involves buying some sort of hardware that you point at your monitor so it can measure the colour quantitatively. You can so some "calibration" without hardware using just software, but then it depends on your eyes and is subjective. Then you need to make sure you have all the colour management stuff set up properly on your computer (usually in the operating system you select the colour profile you created during the calibration procedure and use that for your monitor). Then when you save files to be sent out for printing (eg. exporting from your favourite software) you make sure that you inlcude some reasonable colour profile, most often sRGB. Then you need to make sure that your printshop is half-on the ball and their printer recognizes the colour profile and ALSO doesn't "tweak" your photo to make it look "better." Then it should work out.
Sometimes you can get colour profiles for printers themselves. I believe this helps you properly predict what the print will look like by simulating the effect on your monitor. I don't think you are supposed to export the files with this profile however. Try searching the web on this subject. It's a little complicated.
