Originally posted by gatorguy I would still keep a local copy, and in fact ALL my photos (other than the one stars) are kept on external drives that can be easily carried to another computer if I wish (and have) and NOT on internal storage. I think it would be something you might regret if your only copy of a photo exists "in the cloud".
I know there are those prosumer shooters who use Adobe LR cloud as their photo repository and might only have a few special images if anything stored locally. I wouldn't even consider that myself.
Originally posted by Igor123 I never thought about speed, but just tried a run and I get 10-15 mbyte/s upload (~100 mbit), and I'm in Sweden while their servers are in the US as I understand it, but I think that may be my ISP upload limit so perhaps not a backblaze limit. But since that just uses some disk and network and no cpu and could basically be "always on" if you wanted to, even while editing photos without interfering much with performance since it doesn't use a lot CPU, GPU or RAM, so I don't think the upload speed should be an issue anyhow?
Regarding what to backup, as I mentioned, with the commandline tool and b2 storage (and not the "whole computer backup"-plan) you can easily specify what to backup and not to further limit whats uploaded. The computer-backup has some build-in restrictions on temporary files, application files etc, so you can't restore a computer installation with OS and all from it, just the data. In my case I just run
b2 sync --dryRun --compareThreshold 1 [path to my photo storage]
to sync see what will be uploaded from the photo raw drive, no actual transfer, and then
b2 sync --compareThreshold 1 [path to my photo storage]
to actually to the sync, but there are many options and details that allow for customization and you can run this on a schedule in windows or linux at least (probably in macos too). The comparethreshold-part is just because linux uses different precision of file datetimes compared to windows, and I use both, so maybe not necessary in your case.
As for security as someone mentioned, you can either encrypt it yourself before uploading, or they also have support for you to provide/configure your own encryption key locally so that Backblaze themselves can't decrypt your data even if CIA tried to force them =).
Edit: About uploads/plan; since you define what to upload or not with b2, and it's all "syncing" and not uploading all the data every time, I don't see how you can get a full cloud backup using any less data no matter what solution you use? (Sure the whole-computer-plan from backblaze will backup more, but no need to use that). Or what you could do if willing to spend the time and effort you could try to compress raws using 7zip or so before uploading, but that won't gain much when dealing with raw files and also not worth it I think, since youre not doing that today? (nobody is probably..). But all in all, even if you just get 0.5 MB/s, leaving the computer on overnight would solve that, so the upload speed shouldn't be an issue regardless of plan I think. (if there's a cap on total upload in the plabn there might be issues, but that would go for any cloud backup regardless, and be more related to what you upload rather than to which cloud...)
Interesting. It does sound like backblaze could do what I want. Set up just a couple of folders for it to watch and sync (a personal folder and work/photos). My issue with cloud stuff (in the past) has been that my internet gets stuffed as soon as it's syncing. Yes CPU and RAM are ok, but what use is that if you can't browse a site lol. So either I do the old school thing and sync at night only or have the ability to pause the sync in the day time or at least cap its speed so it's not wholly taking a gazillion years to render websites.
Can backblaze easily do that from a taskbar or something/pause or change upload speed? My speed will be far less anyway, 3-10mb/s...
Originally posted by fs999 I wouldn't use SSD drives for backup, because of the write limitations...
I have opted for a NAS, after a disk overwrite (the vendor said the disk bay was hot swappable... It was not
So I have now a WD my cloud EX2 ($300) and a WD my cloud EX2 Ultra ($600) NASes. One with 2x1 TB mirrored WD Red drives, which are full now, and the Ultra with 2x4 TB.
I put them in the cellar with a 1 Gb network cable connection. So now I can backup every evening, it takes a few minutes, and all my photos are accessible, for me alone, in the whole world, if I need it.
I am also planning to buy a surge protector so the NASes could safely be shut down.
NAS still means at home tho doesn't it? I must have an off site solution, no question about it...
Originally posted by RobA_Oz If your primary concern is loss of data through a home fire or other catastrophe, keeping a backup drive off-site is a much simpler solution than trying to backup your files on a cloud service. I used to do that with a drive I kept at work, but since I retired, I no longer have that option, so my solution is to keep a drive with a relative.
On the matter of SSDs versus HDDs, I recently tried to find a drive to replace the one in my daughter’s MacBook Pro, and was surprised to see that they are getting harder to obtain, even though they’re still available via eBay and the like. I opted for buying an SSD from a local store, which wasn’t that much more expensive than its HDD equivalent. As for rewrite limits, HDDs fail too, but using an SSD as a backup is probably fine, as long as you aren’t backing up every hour or so.
Nearest relative is on the other side of the world, my wife contracts (so the office she uses is not permanent), my other job has no office... really there is no local off site, and I prefer not to use my friends for stuff like that (I mean I catch up with different friends maybe once a month, too large a delay between hdd swaps etc).
Cloud definitely is the way to go, it's just selecting the right provider...
With SSD's vs HDD's in terms of writing, I take it doing stuff like incremental backups makes no difference? Like... if writing to only new sectors as opposed to wiping and backing up all over again, is that a different to the longevity of a SSD?
Originally posted by gatorguy Cool!
Originally posted by clackers I think the surest, lowest tech way are Week A, Week B USB hard drives that your data's synced to.
Each you bring home and attach to the computer in alternate weeks while the other leaves with you the next morning to spend 7 days at your workplace.
If you're real paranoid ("Won't they be together at home one night of the week?") you get a Week C hard drive. Having that Week C one at work fixes that, but of course it's now up to two weeks behind in its files list - unless you sync to both Week A and Week B first, then it's back to one week.
Sadly not viable to me (read above).
