Originally posted by Rondec Just to be clear, when you are choosing a number in Raw Therapee, it is not how many images to use in a pixel shift image, it is which of the images should be used as the "base" image if there is some movement between frames. If there is no movement, there will be no difference between Lightroom and RT. If there is movement, RT can handle it in a variety of ways.
Thanks for that information!!!! I didn't realize that. I've been chasing a number of items - using the most recent take from this road trip we took on July 3 - a 14 hour goat rope that turned out to be almost epic.
One more question, and I've contemplated this for quite a while now. Unfortunately I didn't have the presence of mind when I was out shooting to give it a try. I had the perfect opportunity, but didn't think to follow through.
When I am shooting the foreground landscape for an AstroTracked image (Milky Way over some landscape) - I usually shoot at least a 2 minute landscape frame (it's dark out). This time it was soooo dark, I shot a series of 4 minute frames (and now I feel I should have shot for 6 minutes). I'm really seriously considering shooting sets of 30 second PS frames (2 minutes of "light" in total for each PS frame), perhaps 1, 2 or 3 sets, and then stack them together. My thinking is I can either shoot a 2, 4 or 6 minute frame,
or 1, 2 or 3 PS frames - same amount of light, however the PS frames are essentially "post processed" to a degree, providing the potential of additional color, lower noise, and greater dynamic range - all good. It essentially takes no additional time to do this, and there does appear to be some additional potential benefits. It certainly can't do any harm (famous last words). I'm kicking myself for not realizing this at the time. Also, since with the PS frames, the 2 minute shots are broken into 4 - 30sec shots, and the noise - especially the white dot noise, should be averaged down if not out, along with the effective ISO value averaged down.
One downside to this idea, is - there is this location I want to start shooting in a few weeks, that has a set of road switchbacks down the side of a steep canyon wall. The PS approach will not work well at all with this location due to the changing headlights (and physical motion). So, I think that this potential approach needs to be judiciously applied based on the situation at hand.
We were out in a Bortle 1 location, no moon, clear skies, no breeze - absolute darkness. The sky was lite up with the stars so much, I cast a shadow on the ground, with just the ambient starlight.
