I trialed and then purchased Gigapixel AI for a professional project with very demanding specs. I can't show you the images, unfortunately due to contract restrictions. But I can tell you what I was asked to do and did.
The Hirshhorn Museum in Washington DC will be mounting an exhibition of a gift of Marcel Duchamp's ephemera and smaller objects/multiples. Two of these are iterations of "The Green Box" and "The White Box". These boxes contain assembled notes for his work. The designers and curator of the exhibition wished to have a way to display the contents during the exhibition, but this requires constant rotations as the materials cannot be exposed to even the low FC levels of the museum. They cooked up the idea to have a 1:1 image of the contents as a photo background on which individual bits could be rotated and laid on top in proper position, preserving an exact 1:1 correlation between image and artifacts. The curator assisted by a conservator and the designer arranged all of this on a sheet of foam core, and the whole bit was wheeled into the photo lab and shot on a large motorized copy stand using high cri color adjustable LED lights, but no polarization. Shot with a 645Z. The array was too wide for my 645 55 lens at full column extension, so I had to use the DFA 35. Something of a torture test in more ways than one. If you ask why we didn't stitch, there were multiple technical/logistical reasons during the shot, and I wondered in this case if the stitch wouldn't bring in its own problems (pretty densely detailed image, and due to the nature of the materials pretty easy to see any stitching goofs...)
The whole desired image of each exceeded the 1:1 capabilities of of even my 645Z at 300ppi, so some uprezzing was required. I uprezzed one 1.5x and the other 2x. The design team decided to convert the photos to B+W so that the originals could be very easily distinguished against this photo background by the public. All of this will be displayed flat in plexiglass topped vitrines, the overall size about 44-ish inches on the long side.
Yesterday we finally pulled a full size test print off of the graphics department's plotter-printer (so not the best print for photo). For the Green Box materials, arrayed in a dense overlapping cluster, I was quite pleased with the results resolution-wise----a very clean result. it was better than I expected based on the image on the screen. The other image has not been printed yet, but it looks better on the screen than this first one, so I expect it will be quite good.
That said, I had my doubts as I was processing the images. In initial processing trials from tiffs out of LR, Gigapixel AI's auto settings produced alarming halos and strange "vermiculation" artifacts among areas of random textures. I had to dial down my normal sharpening and contrast settings in LR quite a bit
and reduce output sharpening to low, and I had to use the manual settings in Gigapixel AI and reduce/tweak the default setting there as well. There are only 2 manual slider settings unfortunately, IIRC.
I hope to have time to produce a Youtube video on this when I have time(cue hysterical background laughter) in the next few weeks.
So, to recap the salient points and add a couple:
- Good to excellent results are possible when used with care. Combined with judicious leverage of dpi in a print very large prints can be produced.
- Care is absolutely required!
- The program adds sharpening and contrast, so pre-process accordingly!
- It's an open question how far you can uprez---I bet it's very image dependent.
- The software needs more and better manual controls
- The "AI" part needs further development
- Odd artifacts can be induced---watch those blank or random textured areas
- I bought the software at full price---I buy things I need but I don't spend frivolously, and my money is a vote of approval.
I am anxious to do some trials of this with some of my own artwork images. For me, a 40-60-ish inch long side dimension for the things I am doing right now, multiple vertically oriented shots in
n-tychs would be a sweet spot. With a triptych, for instance, I could have an overall framed dimension of floated images about 64-ish by 140-ish inches, which is as big a work as I want to handle (and pay for, even printing and framing/glazing myself) right now.
