Originally posted by Ghillie I guess I must have been out of focus
Hard to tell from this image - the pixels have been averaged. But the edge of the sun is not very sharp.
Can you give us a cut-out of the edge of the sun, with no pixel averaging?
There are other problems here, too. The sun is overexposed, which will tend to wash out any "blemishes" in front of the sun itself. All that fogging around the sun should not be there for a proper exposure - the background should be BLACK!
What solar filter were you using? It may be too much! (And, could also be the cause of the fogging around the sun.) You've got the ISO cranked way up to 3200. Your aperture is 5.6, which is probably wide-open for the lens, whereas f/8 or f/11 would almost certainly give sharper images.
Before the next solar event (Eclipse 2024?), I suggest you experiment with solar imaging - it should be easy to use ISO 100, f/8 or f/11, and shutter speed in the 1/2000 to 1/4000 second range. Note the exposure in my EXIF data above. This image was taken with a ND 3.0 filter - exposure factor of about 10 stops, and 2X and 1.7 X teleconvertors - f-stop losses of about 3.5 stops. So, my total filtration was 13-14 stops. If you have a polarizer, that will knock off another stop.
Also, practice focus. If your lens is autofocus, it can probably focus on the edge of the sun. But otherwise, you will want to practice manual focusing.
