Originally posted by Gorgarath So, I bought Lightroom 3 several years ago when I originally was planning on getting my first DSLR as it was on sale. I also have the old install disks for Photoshop CS 3 available at work since we no longer have those laptops for which it was purchased. (I hadn't actually even installed it on the laptops for the last couple years that we had them as no one used it and I could use the drive space.)
I've used GIMP/PS in the past for some image editing/drawing but have never done actual photo post-processing before. From what I understand, I might not even need PS since LR can probably do most everything I need. But the question is, should I bother with LR 3 or should I go with something else? Should I bother installing PS as well? I'll probably install it, because why not, but will I actually use it? I'd rather not go subscription based, but I'm not 100% (probably only about 90%) against it.
As I'm new to post-processing, I'd obviously like something that's easy to use/pick up, but preferably also has advanced tools that I can get into down the road without having to switch to a new program. But better to be easy to use just so that I actually use it instead of getting frustrated at it and not using it. All of my personal machines are currently Windows based, but I'm a huge fan of the BSDs which will also run Linux natively through the compatibility APIs without having to compile specifically for BSD. Though, if there are FreeBSD ports, even better. I'm now going to have to go check what the current state of affairs on the software I use on my laptop currently is as I have a strong urge to convert it as I don't have as much need for Windows on it if the couple of things I use it for will work...
My goal is to preferably not spend money that I don't need to spend but still be able to get good results. And while I said I want easy to use, I don't mind if it's not a single program that does everything or if it's several programs that one would use in succession to get the job done. I'm a fan of the UNIX method of small programs that do one thing, but do it really well.
I rambled a little in here, I apologize. I tried to go back through and make it somewhat coherent, but it's a habit that I doubt I'll ever break. Thank you for sticking with me and for any advice you would like to give.
It might be worth you giving Affinity Photo a try. It's a full featured processing program with a 2 week free trial and $50 one time fee (often on sale), all future updates included. Many, but not everyone, have found it to have a gentle learning curve compared to many programs (i have). It does not have a file organizing feature like LR, however, but it's rumored one is under development. Lots of tutorials and an active forum for support.
