Originally posted by jcdoss It sounds like everyone else has found complicated and clunky ways to handle PS-RAW files also. So, where's the advantage of having this feature built into to this awesome camera if the company, or no other company is going to support it in an editor properly? Is the original intent for in-camera jpgs only? The inclusion of an HDR mode that also can't be post-processed without heroic measure and hours of internet research seems to suggest, yes, these special shooting modes are not intended for raw files. Why not just burst out a few frames (four if you want to be precise) and merge them? Won't you get the same, or a similar amount of detail without beating around the bush?
I think you make the process sound way worse than it is. The point of pixel shift is to have an image with more detail (particularly more color detail), better dynamic range and lower noise. You can shoot out of camera jpegs, but to me, these are not going to maximize your results.
The different programs I have used to edit the DNG files are as follows:
Lightroom 6 -- this combines the four images with no motion correction. As long as there is no motion in your image, it works well. Any image that includes water, tree limbs, etc is probably going to have strange artifacts with it.
DCU -- this has motion correction options as well as all of the presets that are available in-camera. You can also save a TIFF file from here for processing elsewhere. It works well, but doesn't have all of the features of Raw Therapee. In addition, it is really slow.
Raw Therapee -- this is my favorite as it allows the most adjustments to the settings. You can choose auto setting which masks out the motion areas. You can do some different custom features as well and you can see the motion mask, which as I mentioned before, I find really handy. I do not do my final edit in RT. I have a preset that I use to create a TIFF file that I take into Lightroom and process, often with Nik Effects. Using the preset literally adds about 30 seconds to my work flow. My experience with super resolution techniques is that they are far less automated and require a lot of work to get similar results.
From Pentax's standpoint, they did include DCU with the camera and it is able to process those images and that is probably good enough. I would just say again that I feel like with a good pixel shift image I am getting close to medium format quality from my K-1 cameras. It is therefore worth it to me to have another minor step in my processing of these images, whereas with super resolution the extra step is a much bigger time commitment and didn't provide any benefit for pixel shift.
