Originally posted by rfortson Why do you think the Pentax software forces you to convert from raw? In my experience, you can save it in a variety of formats (if you like), you can save the raw settings for that file (or group of files), and you can print the raw file after you've edited it. I've never seen where the Pentax software acts any differently from any other raw processor in terms of file handling.
So, let me get this straight. Using the Pentax software, I can browse my PEF files with the Browser, go into PPL of them to process some of them, exit the processor *without converting*, and see the changes reflected in the Browser? And these changes are remembered forever, including after I've exited the Browser and come back? And if I decide I want to do further processing PPL, I can simply re-enter PPL and find everything just as I left it, without having to do anything special to make this happen? And if I want to then do further editing to the image that cannot be done via PPL, I can send the PEF file itself off to an editor and find the processing I've already done intact, giving me a starting point for further editing? Similarly, if I feel like printing a set of images form the browser, or view them as a slide slow, or generate medium-resolution web conversions, I can select a bunch of PEF files from the browser and have them printed/viewed/converted with all the processing I've done intact?
If so, I can't see how using the version of the software that came with my K200D. When I exit PPL, my changes are lost unless I convert the file format. And if I do that, I of course see my changes intact in the converted file, but when i return to the browser, my file looks exactly as it started - none of my changed are reflected in the browser. Of course, from PPL, I can also save the settings I used, but again, these are completely ignored when I return to the browser. They are even completely ignored if I return to PPL - I have to explicitly reload the settings. And the save and load dialogs don't even give me filenames based on the current image name - I have to actually type in a name for the INI file both when saving and loading, and hope I get the right one for the image in question. And these settings are useful only from within PPL - if I want to do further editing with those settings intact, there is no way to do so from the PEF file. I have to convert to another format first. Same if I want to print a bunch of images from the browser, or view them in a slide show, or generate low-resolution web conversions, or anything else I might want to do: if I select the PEF files, an previous processing I made is ignored entirely. The only way to get my processing to be used is to convert to another format and work with the converted versions.
Again, I'm not sure what I am not doing to explain myself correctly, but this is *completely* different from what modern applications do. With modern applications - such as LR, which you are now using, yes - the workflow is exactly as I describe it above. That's night and day in terms of file handling! To the point where you couldn't pay me to shoot RAW if forced to use the Pentax software.
Quote: Just curious why you feel the Pentax software is somehow forcing a file format conversion.
It is if you want to *see* your processing after you are done, or do anything else with those images.
