05-12-2020, 08:06 PM   #1
Hayashi's Avatar
Some K-1 raw cannot be edited by PDCU
Hi guys,
Because of the Wuhan Corona virus, I recently have some leisure time to look back my previous K-1 photos (in DNG format).
Some of them I have already edited and saved as JPG before, but I want to apply a different color style and white balance to make another JPG.
After I finished editing with PDCU, it says "failed to process", please see in the attachment.
The thing is, not all my K-1 raw files have this problem, only some of them have this.
The PDCU is now ver. 5.8.6, can anyone give me an idea what is wrong with it ??
Thank you in advance !
05-12-2020, 08:13 PM - 1 Like   #2
ramseybuckeye's Avatar
If you haven't already, close everything down and restart your computer, and then try again. It could be a memory problem that just needs cleared.
05-12-2020, 11:25 PM   #3
Hayashi's Avatar
QuoteOriginally posted by ramseybuckeye Quote
Tried, no luck.
Just did some test...
If I only do a few (one or two) changes to RAW, like changing the EV and w and then save as JPG, it works
So... could it be a file size issue ? or too much work load for my laptop ??
The CPU is i7-8550U 1.8GHz, with 8GB Ram
05-13-2020, 01:01 AM   #4
Unregistered User
Guest
QuoteOriginally posted by Hayashi Quote
Tried, no luck.
If you know which files cause a problem, compare them with ones that do not. Do not only look at EXIF but also at Windows file information. Can also be that you try to save it to a folder of which access is blocked by Windows. So try to save them to another folder. Preferably on your laptop self and not on a network drive.
05-13-2020, 02:54 AM   #5
pschlute's Avatar
What are you trying to save as ? jpeg or tiff ? Are you resizing the image before saving ?
05-13-2020, 09:25 AM   #6
Not a Number's Avatar
You laptop might be running out of memory especially if the Raw images are pixel shift. I think if you switch off pixel shift processing it will only use one of the Raw pixel shift frames.
05-13-2020, 05:00 PM - 1 Like   #7
PDL
I have seen this with my K-3II and my K20D when shooting DNG's.
I modify the EXIF information to include Lens Name and in certain images I will "correct" GPS information. PDCU does not like you messing with the EXIF information.
I have run a few DNG images through LR (v6.14) and after LR writes crap back into the file - PDCU will not open them. These days I use PDCU only for pixel shift but it really gives disappointing results, so I use it only on very rare instances. If you create panoramas in either LR (DNG's) or Affinity Photo (TIFF's) PDCU will not open them either. My machine has plenty of memory (24GB) so that is not my issue.
05-13-2020, 11:01 PM   #8
Hayashi's Avatar
QuoteOriginally posted by AfterPentax Quote
Just did some more tests...
I figure out that the problem would come out, if some certain DNG photos are edited by:
"Lens Aberration Correction > Color Fringe Correction"
Only this matters, all other changes is fine.
But the thing is ..... I wanna edit the photos taken by FA-31mm Limited, this Color Fringe issue is quite significant on FA-31mm.
---------- Post added 05-13-20 at 11:04 PM ----------
Thanks for the suggestion, but this is not the case here.
Files got the problem and files got no problem are almost the same size, around 44-42MB.
Plus, I still can edit and save JPG from pixel-shift DNG taken by my K-1.
---------- Post added 05-13-20 at 11:06 PM ----------
My goal is from DNG to JPG, so that I can share to my wife.
No resize, 36MP.
I did try with different JPG quality, from 1* to 4*.
No luck, PDCU still say "failed to process"
05-14-2020, 12:26 AM   #9
pschlute's Avatar
No resize, 36MP.
Try resizing the image. 36MP is huge for any kind of screen viewing. I resize to 2158 x 1440 pixels (3.1 MP) to suit my monitor. It may be that your computer is just not powerful enough to process such large image files.
05-14-2020, 03:20 AM   #10
MarkJerling's Avatar
Tried, no luck.
Most probably running out of memory or graphics board memory. I've had it with mine as well and I'm running i7-2820QM @ 2.3GHz with 16GB RAM.
05-14-2020, 06:35 AM   #11
pschlute's Avatar
QuoteOriginally posted by MarkJerling Quote
I don't use the Pentax software but have had struggles in the past occasionally with Photoshop and Silkypix when processing raw images, especially when trying to process multiple files.
The biggest change I made was when I switched to a new computer running windows 10 and more importantly a SSD where I install my programs. No hangs now.
05-15-2020, 11:21 PM - 1 Like   #12
Hayashi's Avatar
Thank you guys for all the suggestion.
The problem suddenly gone, out of no where.
I can edit and save JPG of the files which I couldn't before.
Kind of X-FILES !
dng, fa-31mm, files, folder, fringe, jpg, k-1, laptop, pdcu, photography, photos, photoshop, pixel, pm, post, shift, windows
Are Most Photos Edited To Some Degree? fstopfanatic Photographic Technique 45 05-24-2016 10:50 PM
PDCU 4 and RAW DNG images from a K5/K7 - noise handling questions. jpzk Digital Processing, Software, and Printing 6 11-26-2014 02:00 PM
Posting some MX-1 pictures I edited in UFRaw & GIMP on my 7 year old laptop. MD Optofonik Pentax Compact Cameras 3 03-24-2014 08:05 AM
Faststone question, how to save an edited RAW file for further editing dmnf Digital Processing, Software, and Printing 10 07-17-2013 07:43 PM
PDCU: overwrite RAW or save altered RAW-file Alfie Digital Processing, Software, and Printing 4 09-27-2012 09:33 PM
All times are GMT -7. The time now is 05:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
