Originally posted by biz-engineer I guess this is kind of a general rule and it doesn't fully work for my eyes.
It is a guideline based on the maths of visual acuity based on someone with 20/20 vision. Obviously if your vision is better or worse than 20/20 the recommendation will change
Quote: ...
My visual acuity isn't a constant vs distance. So that means, if I print small, I need proportionally less resolution than if I print big, contrary to common belief. That could mean, for example, I'd print at 300 ppi for a small print viewed at 12", I would still need 250 ppi instead of 150 ppi for a print 2x larger viewed at twice the distance , 24" for instance. So, at least for all people like me, a larger print viewed from further away will still benefit from more pixels than the common 300 ppi at 12".
The idea of PPI and print size needs to be understood. The required PPI is the figure that at a given viewing distance an image comprised of dots will be perceived as a continuous tone . In other words a viewer will not see the spaces between the dots.
Contrary to what you seem to have found is the fact that a smaller print will, if viewed at a reasonable distance require more pixels to resolve detail that may be contained in your image data than an enlarged version may require viewed at a similar ‘reasonable’ distance - taking into account that even if detail is present it may not be able to be seen with the unaided eye due to distance from print.
I prefer to think of what minimum pixel requirements for a certain viewing distance than the commonly quoted 1.5 - 2x print diagonal. So I use the 3438/estimated closest viewing distance for a print to be viewed in a particular setting.
So, as an example an 10x8 image viewed at 12” would require a minimum of 286 ppi whereas a 20x16 images viewed at 24” would require a minimum of 143 ppi when viewed at 24”. Note figures quoted can be considered to a degree moot, due to the way printers handle image data!
The commonly quoted 300 ppi is somewhat of a myth relating to inkjet printing and visual acuity. 300 ppi is the lower resolution required by Canon and HP printers and is one that some quality magazines require for offset printing. They will use lines per inch (LPI) and may quote 150 LPI as the requirement, which when translated to PPI will require a minimum of 300 ppi.
Epson as already covered require 360 ppi at the lowest resolution requirements.
Regardless of what you think you are sending to the printer in PPI your image if outside of the printers declared resolution will be resampled to the printers requirements prior to printing. So your examples of 150ppi and 250 ppi would be resampled to 300 ppi for a Canon printer or 360 ppi for Epson
---------- Post added 04-23-21 at 11:17 AM ----------
Originally posted by house Different images will require different resolution prints. Any rule of thumb can be significantly broken.
Not really anything to do with rules of thumb, as has already been covered in depth
