Originally posted by Serkevan When I eventually decide to settle down and build a desktop (those two things go hand in hand
, a gaming laptop every 5 years is plenty for now) I'm probably gonna go for AMD just to get all that Ryzen goodness.
Congrats on the rig!
Intel CPUs still have a slight lead on single thread performance, but these new Ryzen chips offer so much bang for the buck & still have very decent single thread performance. This "basic" Ryzen 5 3600 is quite amazing to me & it technically only uses 65 watts. Much less than the 125 watts with the FX-8350.
I can still eventually replace the CPU with a higher end model. The one CPU that I would really like to eventually get is the Ryzen 9 PRO 3900, but AMD doesn't sell it to regular consumers. Maybe I'll eventually find a used one on eBay. It only uses 65 watts & can crunch a serious amount of numbers.
Originally posted by ehrwien Not unexpected and not uncommon, even if the RAM had been on the QVL. XMP is an Intel thing in the first place, so from what I hear that alone makes it finicky on AMD systems. Running it with all 4 slots loaded doesn't make it easier. The thing to do is to not use XMP, but to manually choose higher frequency, timings and voltages. There are great guides out there to help you with that, there are even pieces of software you can plug in what RAM you have and it will tell you how far you should be able to push it.
With modern CPUs that's mostly wasted energy anyway. You have your "stock" speed and the integrated turbo range. It will depend on your cooling solution (stock cooler?) how high this will get your core frequencies and for how long. Then there's Precision Boost and Precision Boost Overdrive, which you could just tick on in the BIOS, but from what I heard that does not yield that much performance, especially wrt the energy input... I do run my 3600 on stock settings as well and I'm happy with that. Apart from... well, the overclocked RAM, which is in a way also overclocking the CPU, because the RAM controller sits inside the CPU. With Intel you're essentially already voiding your warranty when enabling XMP, even on K-processors (the unlocked ones meant to be oc'd) and Z-boards.
Good to know about the RAM. It works perfectly fine as it is & it's not like I need to overclock it either. I figured if the BIOS could handle XMP Auto, then I'd leave it, but since it can't, I'm fine with that. The RAM works great as it is.
Yes. I'm running the stock cooler 'cause I didn't plan on overclocking the CPU at all. I would get a much better fan like a Noctua or something like that & add more fans to the case if I ever ended up getting a Ryzen 9 PRO 3900, 9 3950X, 9 3900X, or 9 3900XT processor in the long run.
