09-22-2020, 08:38 AM   #1
Possible to edit exif data in Raw?
A series lenses don't report lens model or focal length. Focal length can be entered if the camera body has SR. Works for Q thru K-1, but the 645Z doesn’t have SR. SR work around falters with multiple lenses of the same focal length.
Is there a program that allows adding missing model and focal length? Found many programs that edit the data, but none say they work with Raw. I only shoot Raw.
Thanks,
barondla
09-22-2020, 08:43 AM - 1 Like   #2
pschlute's Avatar
QuoteOriginally posted by barondla Quote
A series lenses to report lens model or focal length. Focal length can be entered if the camera body has SR. Works for Q thru K-1, but the 645Z doesn’t have SR.
Thanks,
barondla
Try Silkypix DSPro. I recently got the DFA 85mm 1.4. This is not recognised by my version of Silkypix but it does of course recognise the FL. I am able to add the lens name to a raw file during raw conversion and I only need to do this once. Subsequent conversions remember the name
09-22-2020, 08:43 AM - 1 Like   #3
vector's Avatar
I don't recall having ever edited exif, but I have used exiftool to pull data from exif. It has exif write capabilities though.
ExifTool by Phil Harvey
Edit: Forgot to mention that both DNG and PEF are supported formats.
Example:
exiftool -m -exif:FocalLength=85 -exif:FocalLengthIn35mmFormat=85 filename.pef
09-22-2020, 09:09 AM - 2 Likes   #4
jcdoss's Avatar
If you're using Lightroom, look for a plugin called Lens Tagger. I have been using it for ages. It allows you to edit lens model, focal length, aperture, and provides space for adding film data if you're using film bodies. It uses EXIFTool as a base, but works thru a popup in Lightroom. It's the first thing I do when I import anything.
09-22-2020, 01:10 PM - 2 Likes   #5
boriscleto's Avatar
NameThatLens
Doesn't need Lightroom
09-22-2020, 02:47 PM   #6
Otis Memorial Pentaxian
QuoteOriginally posted by boriscleto Quote
NameThatLens
That looks pretty cool. I usually use ExifTool + ExifToolGUI, but NameThatLens looks to be a great alternative. Bookmarked!
data, exif data, length, model, photography, photoshop, sr
O-GPS1 and your EXIF data - When the GPS is on, it strips data from the EXIF? Sagitta Troubleshooting and Beginner Help 17 11-23-2016 02:25 AM
Does EXIF data include ISO or Aperture data? Newtophotos Photographic Technique 7 09-04-2013 12:41 PM
How do I edit the EXIF data on my pictures on MAC? Student Photographic Technique 4 02-08-2011 03:08 PM
Edit Aperture Data In EXIF?? VIXIV Digital Processing, Software, and Printing 3 02-19-2010 02:29 AM
K20D/SMC 'M' Lens. Can I edit exif data? trublubiker Digital Processing, Software, and Printing 4 06-22-2008 05:50 PM
All times are GMT -7. The time now is 06:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
