Originally posted by Larrymc Nope, not true. I have an NVIDIA Quadro K2100M 2Gb GPU, Core I7-4810MQ processor with 16 Gb ram CPU and a Dell Precision M4800 board and I get excellent results with DeepPrime as a matter of fact DeepPrime is much faster than using Prime as Prime uses only the CPU to process the image where as when PhotoLab is set up to use both processors the time for DeepPrime is shortened quite a bit. When using just theCPU or GPU its agonizingly slow.
What I said is true. Your system is mid level and well beyond the minimum requirements. Actually you have a 4th gen i7 which is in the recommended category in parenthesis for the very requirements I quoted from DXO. As is the 16GB of Ram your computer has in it. And you've got twice the video ram than the minimum requirement.
Minimum are far lower than that. I have minimum in my i5 450 and 1GB Radeon video on an old laptop. And it takes many many minutes to render an image in deep prime. So, again, I'll say you don't want minimum requirements but recommended or better (as you have).
