Do not be afraid of 4k screens
if your intention is to print and you want to get the the best idea of how a print will look with sharpening and noise reduction.
If you are not concerned about printing and want to mimic on your screen what most see on their average monitors of 100 PPI and less than full sRGB coverage save some money and look for a standard monitor.
High resolution monitors will get you closer to the view you will have with big prints. You will be able to see the full image and also observe the the detail inherent in your capture due to the greater pixel density. And also have the benefit of getting a truer view of sharpening and noise reduction requirements by viewing closer to print size (in this case not as close as ideal but...)
Consider the Apple iPad retina screens resolution from 264 PPI to 326 PPI there is a good reason why Apple went this route.
The typical pixel density of a 27" 4k monitor is around 160 PPI such as your linked monitor some 60% greater than 'most' standard 24" monitors. So not such a huge increase, but nevertheless a useful one (for print size viewing sharpening and noise reduction purposes). A 24" 4k monitor may make even more sense due to more PPI
One issue that can occur is of text sizing with high resolution monitors with certain applications. In the early days using PS CS6 and earlier the advantage of high resolution monitors for image viewing was seen but the major problem was of text and dialogue box sizing. In short you could not resize text due to the limitations of the application (and possibly the OS). With newer applications I suspect this no longer an issue
I do not know this particular monitor at all so really cannot make comment other than to say try before you buy if at all possible. One downside is the limited gamut, at least compared to Adobe RGB, said to be around 122% sRGB. If you could find one within budget you may want to consider a 24" with say 98% Adobe RGB gamut. Again the most advantage in printing (sRGB is the worst colour space to work in for print!) with all printer paper combinations likely to exceed sRGB gamut and many able to exceed even Adobe RGB in some areas.
We are all likely to be budget constrained so you will have to balance your needs with that budget. If budget not an issue then really there are only two manufacturers for photo monitors, Eizo and NEC. You may be looking at £2,000 - £4,000 though!
