Originally posted by Chapel Hi Boris, not to hijack the thread but I just got an Epson 44" printer for a song. I have no idea what resolution to set for my 645z prints. The largest so far is 12x16. Do I change the ppi from 300 to 240 or lower to make larger prints?
Thanks
Greg
Hi Greg,
Since I had the printer for a number of year. I got to experiment a lot with the resolution settings. Most people would say that for larger prints you do not need as much ppi/dpi. That is somewhat true. For my larger prints above 24"x36" I would go down to 240 or even 180. For most part you do not see a noticeable quality drop. However, I did run some test large prints at 180 and 300. I did notice a quality difference. 645Z has a set resolution which would allow you to prints at 300 dpi up to a certain size. I do not remember the math for that. For argument's sake, let's say that size is 18"x24" (3x4 aspect ratio) at 300 dpi. If you print a 42"x56" and you set your size in Photoshop for that particular size, then Photohop will interpolate your image resolution to give you that bigger size. This effectively reduces your resolution/clarity. In a practical level, you do not see much degradation if any for that size increase. I have gone down to 100 dpi/ppi for my K3 for some trade show posters 42" wide x 96" tall with fantastic quality prints. You can get perfectly acceptable prints from really low resolution files. There is a big exception to this rule, If you print for sale as art prints, I would say print at minimum of 300dpi. If you send your work to a pro gallery as "museum quality" prints, they have to be minimum 300dpi.
The other factor that effects the final look of the prints is the resolution the printer uses. I printed at 720 dots per inch as the speed is reasonable. You can go up to 1440 or 2880. Again I did see a difference between 720 and 1440 print but the time trade off was not worth it. If I remember correctly, the 1440 took almost 3-4 times longer to print than the 720. It has been a while since I last printed so pardon me if I did not get the terminology right.
I did push my K1 files to the limit and they gave me very nice 40"x60" prints. 645Z is a beast and should give you sellable 42x56" (40x60) prints easily.
Maintaining an Epson printer and make sure it prints. That is a whole different discussion. I cleaned (purged) the heads a lot. I could not afford to do that with expensive Epson inks. So I found a dealer in California who sold aftermarket ink at 1/5 the cost of Epson inks. Colors were indistinguishable from Epson original inks. At that point I did not care if I wasted a lot of ink purging heads and keeping the printer. You have to print often as Espon does not like to sit idle (heads dry up).
Hope my input helped you some.
Cheers,
Boris
