If at all possible get a rotary cutter with two rails. The single-rail cutters as shown in the Amazon link can tend to wobble from what I hear, especially the less expensive ones. Years ago when I was doing Cibachrome printing I had to be able to cut 16x20 paper into smaller 8x10 sizes
in total darkness to create test prints for checking colour balance and exposure. I couldn't use 8x10 paper because that would mean a change in batch number and possible inconsistent results. My solution was a professional Dahle guillotine cutter with clamp. The cuts had to be 100% accurate 8x10 cuts to fit into the processing drums I was using. The cutter was around $400 back then.
---------- Post added 2021-03-30 at 04:10 PM ----------
Originally posted by JohnMc That Dahle cutter looks very good for the price. The wobble I was referring to in my earlier post comes from the single
round rail so many of these cutters have. The Dahle design should fix that issue.
On closer look at the B&H posting, that single bar (as it appears in the overall image of the cutter) is really two joined as one.
