Originally posted by BarryE I had to look up the Canadian exchange rate as your figures threw me a little. It's available in the UK for around £850 and in the US at $800 (at B&H), which is nearer $1000 Canadian dollars. I guess this is why I mentioned it as, yes it was more than the BenQ, I hadn't appreciated it was so much more in Canada.
I goofed here. Vistek, the only bricks and mortar store in Canada which I know carries wide-gamut monitors, doesn't list the NEC PA243W on their website (all their NECs are special order); therefore I went with the Amazon.ca listing. The figures made sense so I didn't look any further. After reading your post, I checked further; the Amazon listing ships from Italy (
)! I found two online Canadian sites which listed this monitor (one had stock and the other didn't). The one with stock listed it at 1119CAD and the the other at 1306CAD. These figures are more in line with yours, but still a big jump over the BenQ.
---------- Post added 2021-04-11 at 10:01 AM ----------
Originally posted by BarryE You'll probably know this, but it seems many don't appreciate it: most 3rd party calibration software eg Spyder etc., is only a software emulation, it doesn't actually change the hardware. The NEC (LaCie) software and calibrators actually change the monitor's hardware. NEC's calibration software supports 3rd party colorimeters, not just their own. I ended up getting their software for free as there were problems with my delivery and I negotiated with them.
I had my Spyder 3 before I got my LaCie; I was using it to calibrate a CRT monitor. I ordered the LaCie without their colourimeter and then had second thoughts. My supplier, who carried a lot of LaCie stock and was only down the street and around the corner from LaCie's Canadian headquarters, got me their colourimeter at the price I would have paid if I had ordered it with the monitor. In the long run my second thoughts were a mistake. The LaCie colourimeter never consistently did a proper job of calibration; there were software problems which at one point required support from the French head office. In the end I threw it out and stuck with the Spyder 3 which never let me down.
---------- Post added 2021-04-11 at 10:10 AM ----------
Originally posted by Paul the Sunman For the BenQ SW monitors, the calibration software you use is their own Palette Master Elements, NOT the Spyder (or other) software. It DOES install the calibration in both the monitor and the computer.
A good point, but from my comment above about the LaCie colourimeter, my experience was that it was best to stick with the Datacolor software. Overall I found the LaCie software problematic both for their colourimeter and the Spyder 3. But I will follow through on your advice if I get the BEnQ monitor.
---------- Post added 2021-04-11 at 10:12 AM ----------
Originally posted by BarryE So just be careful, then, that users use the manufacturers software, be it NEC, BenQ et al. I've seen many comments that don't appear to appreciate this.
Please see my preceding comment.
