Originally posted by Sholom I haven't done a direct comparison but I have been impressed by the results I've gotten with this workflow.
I finally had some time to do a quick edit comparison. I may have to find tune my exact workflow, but so far has yielded the same, if not better results. Quicker too. I ran RT first and did all non-NR edits there, saved as a 16-bit TIFF, then opened direct in DeNoise (I don't have Photoshop). The only difference is I use sRGB color space since I don't print much. I may go back and fine tune things later, but my time for testing is limited. I may just keep going as it's, then switch up if needed, like if I run into problems with NR like JensE mentioned.
