Originally posted by Kendra59 Is it crazy to go with a 1:1 ratio, when I am using a K-50 16,3 MP camera?
I would select the crop ratio based on subject, orientation and frame fitting.
1) Regarding the orientation: 3:2 in portrait mode isn't ideal (in my opinion). For vertically oriented prints I prefer 4:3, 5:4, 7:6. For landscape oriented prints I prefer 16:9, 3:2 and 4:3. If the display orientation is not known, 1:1 is also suitable.
2) Regarding the fit in frames, there are two cases:
> 2.1) An addition space is need between the frame and the print to write something about the print (e.g name, author , date, place etc..), one side of the mat board is larger than the other sides, in that case 1:1 and 5:4 prints would fit well into a standard 1:1 or 5:4 frames (depending on orientation), 4:3 prints would fit well into a standard 4:3 frame.
> 2.2) If the intention is to maintain mat board borders of equal space, with not inscription on the mat window bordel, then 3:2 prints would better fit into 4:3 frames, 4:3 prints would better fit into 5:4 frames, and 1:1 prints would fit into 1:1 frame. That is because when the frame and print ratio aren't 1:1, there is a change of ration between the print and the frame in order to maintain mat dimensions.
So, the choice of image ratio may depend on the wanted end results, orientation and frame ratios.
