Originally posted by MetteHHH Matter of taste, I guess. I have a usb card reader. It is the second I bought: The first one didn't work. This one is unstable, it often loses connection during transfer, and I end up with some uncopied photos and some corrupt files, and then I need to figure out which to copy again. Sure, I could buy a third one. But I would rather not.
That, and worse, perhaps fatally corrupting the files on the card or the card itself, has been my fear after searching for a card reader and reading the reviews. I actually did buy a "slot" type card reader/usb3 port thing for my desktop pc, but the card reader part never worked (but the usb 3 ports do, which is nice because I have not had ones on the front before, and also the reason I didn't send it back).
I would want usb3/uhs II speeds, without it getting too hot in the process of copying many files, and at best internal and reliable from a "big/known" company, but I think there's just no real market for this type of thing anymore.
Originally posted by Not a Number Using the cable you should be able to get up to 5 Gb/s speeds provided you have at least a USB 3.2 gen 1 port on the device you are transferring to.
In practice you are then limited by the speed of the camera internal controller. With my K-S2 I'm not getting more than 15 megabytes/s, although the USB 2 standard should provide me with 4 times as much. I've got no data for the K-3 III, but I've read that the buffer does not clear nearly as fast as it could be possible for the cards and slot used (and only one of the 2 supports the higher speeds?), so I think when copying from the cards it will be far from the theoretical maximum speed as well?
At least I'm not risking to go out without a card in the camera because I always put in the cable to transfer the files
