Originally posted by ProfessorBuzz Have you got the right Transfer Mode set in the camera?
Menu ... Setup... Transfer Mode... PC
Hi ProfessorBuzz yes I do...and I do not use the same sd card for the different cameras.
---------- Post added 29-06-21 at 09:41 ----------
Originally posted by UncleVanya I think he is moving the sd card out of the camera to the computer.
---------- Post added 06-28-21 at 09:47 AM ----------
That’s weird. If you’re moving the sd card it should just work. Has this sd card been formatted in the camera prior to use?
I am sure I did as I have been using the same sd card all along for my Pentax....My recent photo's are on it for sure they do show on the screen, but when I click on one of the photo's all vanish and the file DCIM file they're in ..... When I go to remove the card from the pc instead of the message remove safely I only get go to drivers and printers. I click on it and it takes me to the control panel where what's highlighted is drivers and printers.
---------- Post added 29-06-21 at 09:47 ----------
Originally posted by Not a Number You may have the camera set to PictBridge for the transfer method. To disconnect just turn off the camera. Then set the transfer mode (as above) to PC or PC-F. Try PC first.
After that the "Safely Remove Hardware and Eject Media" should work.
Hi Not a Number .....nope I have double checked, when I go into devices and Printers there are three things - my laptop, my mouse and a SDDR-113. Does this mean anything?
---------- Post added 29-06-21 at 09:55 ----------
Originally posted by UncleVanya He refers to a card not a cable. I don’t think he is connecting the camera via usb.
HI UncleVanya ......no my Canon does not have a cable I use only the sd card, Bought it on a special. EOS 250d with two lenses a battery and charger only! However, when I use the Pentax cable nothing happens!!!! Do you think I need to reinstall the Pentax... Oh no my laptop does not have space for a CD!! Friggin hell now what..
---------- Post added 29-06-21 at 10:01 ----------
Originally posted by swanlefitte I would say not seeing files after using the card slot is the reason for trying the cable method.
Hey swanlefitte. The first reply I don't have that problem but thanks for that and I have tried using the cable but nothing happens...should I be in picbridge to use cable.
