Originally posted by photoptimist 1. Nothing stops the pano shooter from taking lots of small steps with a larger-format camera -- digital images are almost free.
That's right. While I was testing my pano head setting at home, I shot the dinning room table with the chairs around, very close to the camera, so it was very challenging for Hugin to line-up everything. Then I shot the same scene again with the camera portrait oriented, and rotating the camera 1/10 of the frame for every exposure, I try to stitch again, Hugin still unable to line-up every frame perfectly. Then I simply batch cropped all images in the middle vertically, leaving about 20% of the image width but keeping 100% of the image length, fed Hugin with the batch output.... and I was shocked, Hugin lined-up every frame perfectly, and the total image was super wide angle.
Originally posted by photoptimist 2. Nothing stops the pano shooter from mounting their larger-format camera such that the pivot point is quite close to the nodal point.
Exactly, that's what I was trying to do, but still when the subject matter was 3 dimensional and very close to the camera (closest element of table + chairs was a foot or two feet away from the front of the lens), the stitch output didn't have all lines match, some lines couldn't match. Here, I was trying to test the scenario of a wide angle landscape panorama with a predominant subject in the foreground.
Originally posted by photoptimist Collecting multiple rows increases the risks of subject motion or changes in lighting during the collection process.
Yes, you are correct. So, we may decide to take a greater or lesser number of exposures, depending on proximity of the foreground elements, if there are moving elements in the scene or if the light is changing fast. If things are moving in the scene we can also intentionally do long exposures to smooth out the junctions. Hugin also allow the masking, it's possible to include or exclude parts of images that moved frame to frame. The thing is, fleeting light is in contradiction with doing long exposures, so in that case it is better to take the least number of exposures and avoid a foreground subject too close to the camera.
---------- Post added 15-01-22 at 08:39 ----------
The No Parallax point measurement challenge:
In order to reduce stitching errors, I've tried to measure the position of the no parallax point for the main focal lengths of the lenses I use for panorama stitching, and write those arca rail positions on a small look up card that I keep in my camera bag for use in the field. I was never able to find the no parallax point very precisely.
I tried four measurement methods:
1) The first method I used was to take two vertical matching lines , one line close to the camera and the other line far from the camera, rotate the camera to see if the near and far lines stay matched, more the camera/lens of the arca rail to reduce the mismatch between lines, check again, fiddle with the camera position to find the position that creates the least amount of parallax, visually. There are two problems with that method: have enough depth of field to see the front and back lines both sharp and at the same time not have too much aperture diffraction such the vertical lines appear blurred at 100% magnification.
2) The second method I've used was to take one distant vertical line and an horizontal tape measure closer to camera, note the tape measure number where the vertical line crosses the tape measure when the line is in the center of the frame. Then rotate the camera to the far right or far left, so that the vertical line is at the edge of the frame. Move the camera/lens are one end of the rail, note the arca rail position number and note the tape measure number when the vertical line crosses. Move the camera at the other end of the rail, vertical line still at the far right or far left of the frame, note the arca rail position and note the tape measure number when the vertical line crosses the tape measure. This gives 4 numbers, that describe a line in an X,Y chart, the zero crossing of the line indicates the theoretical no parallax point of the camera/lens in terms of the arca rail position. I thought that method , in theory, should be more precise than the method 1 (above), but it wasn't.
3) The third method was the quicker variant of method 1, and using a vertical line and a tape measure. Lineup the vertical line in the center of the frame, read the number on the tape measure where the vertical line crosses the tape measure. Rotate the camera so that the vertical line appear at the edge of the frame, note that the number on the tape measure has changed. Without rotating the camera, move the camera/lens position forward or backward with the arca swiss rail until the vertical line matches the measure tape number noted when the vertical line was at a the center of the frame. That method works as well as method 1, but it is quicker.
4) For the fourth method, I took a series of panorama exposures for given camera position on the arca rail. Then I fed the images in Hugin, aligned the images and noted the amount of matching errors reported by Hugin. Loaded another set of images taken with the camera at a different position, aligned images in Hugin and noted the amount of alignment error. So, in theory I should find the camera position on the rail that give the least amount of alignment error in Hugin. But that method never worked for me. The reason is that Hugin find a different cloud of control points for every new set of images, so in the end the amount of alignment error given by Hugin wasn't a reliable quantification of parallax error.
