Originally posted by Dartmoor Dave Only a small number of photographers will ever use the full range of geeky potential in apps like RawTherapee and Darktable, so I think the best move that developers could make right now would be to offer an "easy mode" and an "expert mode".
I'd say the same is true for Lightroom and certainly for Photoshop, isn't it? Do these apps have such "easy modes" or would you then just revert to PS Elements, Paint.net or PSP instead? On the open source side one could of course revert to simpler alternatives such as Showphoto (part of the Digikam package), immensely powerful but with easy one-click shortcuts and preset automated adjustments.
Quote: It would really help in gaining wider acceptance if there were versions of apps like RawTherapee that initially installed with just the essential range of controls that 90% of users will ever need made visible, but offered an expert mode that could be switched on in preferences.
Well, if there were enough people who would like that, they'd get up and either join the existing developers team or branch the codebase and create what they need. I suppose there is one major difference there in that with commercial software a company develops software, listens (or not) to feedback and then goes on to develop new options/upgrades/updates/spin-offs. With open source, if you need something, you find lots of others who need it as well and just make it so. I think most of what you want is already there anyway so others have done exactly thàt.
In the meantime, DarkTable developers have created an easy-access panel where you can store your most (or only) used modules. I often use a style preset and my easy access panel (first screenshot shown below) to edit raw files without ever touching any of the more esoteric modules. There is also a "beginners workflow panel" (second screenshot attached) which seems to accomplish most of what you suggest. Both my own personalized "easy access" panel as well as the built-in "beginners" panel are attached.
I sympathize with those who want "easy mode" software and I would never think of patronizing them but such software already exists and is there for grabs (and for free). I myself make extensive use of Digikam and, as I've shown in my write up for this post, use it myself when I do not require the full power of Gimp or DarkTable. A noteworthy application with an easy mode would be Fotoxx for instance. I've never taken to it myself but it looks exactly like the option you describe.
I honestly think though that if people would just spend a bit more time finding about about customization, they would discover that most open source software is easily customizable right from the get-go. That certainly applied to DarkTable but for some odd reason I always see people going on about the user interface having too many modules with too many weird functions. Spend half an hour clicking your user panel together - it will be the best half hour spent, I promise you!
---------- Post added 03-14-22 at 12:27 PM ----------
Originally posted by BigMackCam For those having trouble getting past the learning curve with these open-source tools, I suggest limiting yourself to the adjustments that more-or-less replicate what you'd find in commercial software, and completely ignore the rest until you need it.
That is exactly the right way to go about it. Put those adjustments in your own customized panel and only add in more detailed and technical modules once you learn about them. It is only recently I discovered the tone equalizer module, hadn't ever touched and found it confusing as hell. Once I'd seen a decent video howto and tried it out, it got added to my standard toolbox - no idea why I messed around with the shows-highlights tool for so long. The tone equalizer works in such an amazingly simple way, just by pointing to the shadow or highlight level you want adjusted and scroll the mousewheel - done.
But the real point is that there are only a limited number of pixel-value manipulation algorithms available to image science but an infinite way to combine them. Photoshop/Lightroom do that one particular way, DarkTable another. In the end, in either software you have the options to go for the uncooked step-by-step manipulations or the more complex combined ones - the choice is up to the user.
