Originally posted by nightowl Hi,
I know this is not exactly a photo editing forum, but since I am a pentax user I give it a try:
I am searching a simple photo editor that has the following traits:
following editing functions:
- cropping
- turning in small increments
- brightness, saturation, contrast, gamma
- resizing
following options for presets and general settings:
- working in one window without popups or additional windows
- overwrite changes to a picture with as least as possible, ideally one klick without being asked anything nor opening extra windows for a new saving path, name, file extension etc.
- setting a preset quality of saved photos up to 100%
- quick opening of next photo with one click
- file format .jpeg / .jpg
Photos will come from a Pentax K3 II mostly with a macro 50mm 2.8 and 35mm prime in manual mode in a fixed setting in daylight.
Most photo settings will be preset in camera, so only incremental basic editing adjustments are needed.
I tested many photo editors, but none so far had all features and I have to stack editors.
The editor is needed to crop pictures, adjust small turning percentages, adjust small changes to brightness, contrast etc..
Many pictures need to be edited one for one by hand as quick as possible with least interference by the editor.
I am used to and like this way of basic editing, I do not look for a badge solution.
I am not the biggest Windows fan, but Microsoft 15 years ago had a viewer with editing functions like I am looking for, I was not able to identify the specific software I mean, maybe someone remembers.
I am willing to buy any hardware type and OS needed, but ideally the editor works on PC under Linux or Windows.
Many thanks in advance for your input.
Greetings
Originally posted by GUB Irfanview … does it all and yes, it's still updated regularly … do read the help file, it's extremely comprehensive, if a little cryptic in places.
It's my "image front end" of choice. It can also be configured to send a loaded image to another program for fine tuning, if necessary.
Most regularly used features are available from keyboard shortcuts and it has extensive undo/redo levels.
It'll read Pentax PEF and DNG files, albeit not re-save them, also, it doesn't mess with the EXIF
My typical workflow :
Ctrl-U : adjust rotation (if necessary)
Shift-C : crop to pre-determined aspect ratio (if required)
Ctrl-R : resize if required
Shift-U : auto-adjust levels (can be based on selected area if necessary)
Shift-S : sharpen, if needed
S : save as
Hope this helps
Afterthought :
Of course, if the original files are coming from a Pentax camera, there's always the Pentax-supplied Digital Camera Utility (on the CD in the camera box), which, in it's latest incarnations (download available here
https://www.ricoh-imaging.co.jp/english/support/download_digital.html ), is reasonably user-friendly and extremely competent, though there is a bit of a learning curve to become familiar with it
DCU does have the advantage of being updated to keep up with the latest Pentax lenses etc., if that's a consideration.
