Originally posted by JimD Thanks for your answer but why don't you just say you're not sure
I am trying to give you the benefit of the doubt and assume you were not deliberately being rude, and so I will expand on what I meant, which I did think was obvious......
When I updated to LR, I did so from Adobe Photoshop Elements. This is a much older program than LR. It is logical then to assume that updating from LR 4.4 should be at least as easy, and probably easier, as far as things like Collections and tags are concerned. Are you following me so far ?
Secondly, LR has changed a lot since I started using it, and I am referring to the newer version LR Classic. The develop module has changed significantly, so it is likely some or even many of your settings will need to be re-set from scratch.
Either way, good luck with it. You won't get any further help from me.
