After some encouraging results with Topaz Labs' DeNoise, Sharpen and (to a lesser extent) GigaPixel AI suite which I bought back in April, I recently purchased their JPEGtoRAW AI software, as I own a number of JPEG-only cameras and was interested in its claimed abilities to remove JPEG artefacts, expand and smooth out the tonal range and recover detail. Whilst it worked reasonably on
some files, it actually
added artefacts to others, and after a few days I requested a refund under Topaz' no quibble 30-day refund policy.
My refund was issued within hours (well done, Topaz Labs) - but I also got a nice reply from a support rep with some very interesting information:
Quote: I just wanted you to know that we've incorporated the majority of the features of JPEGtoRAW AI into Gigapixel AI. The same functionality of JPEGtoRAW AI has been incorporated into Gigapixel AI's compression mode. You can use a 1 to 1 ratio if you don't want to upscale, and this will still restore editing capabilities. To clarify, none of the capabilities would be lost by using Gigapixel AI instead of JPEGtoRAW AI. Restoring editing capabilities is referring to the function of converting a JPEG to a RAW image. If anything, the current Gigapixel AI will be better quality as it has our new AI Engine in place.
Gigapixel AI can convert jpg or png files to DNGs or TIFFs. Gigapixel AI's other job is to resize and enhance low resolution images. However, if the resolution or size is not an issue or should be kept the same, then you would want to use the "scale" model and use the "custom" option with an input of '1.'
This will not upscale the image, and it will stay the same size. When saving, you will have the option to create the file as a DNG or TIFF for uncompressed editing capabilities. If you do want to resize or enhance, then you can do that all-in-one step.
Having played around with some of the same problematic JPEGs in GigaPixel AI using the "Low Resolution" model (which works best with JPEG compression artefacts) and x1.00 scale, I'm achieving
much better results than I did in JPEGtoRAW AI, and with all of the benefits I'd originally hoped for.
One photo I had problems with in JPEGtoRAW was a moon-shot taken with my Panasonic DMC-FZ62 bridge camera. The resulting raw had way more and more-pronounced artefacts than the original JPEG image... However, GigaPixel AI did a
far better job. Here's a 1:1 comparison - on the left, the JPEG... on the right, the raw from GigaPixel, with a couple of minor additional adjustments in Lightroom after conversion:
Not bad at all, IMHO
This is not simply noise-reduction... I can get rid of the JPEG artefacts using Lightroom's luminance noise reduction slider, but it
kills the detail. GigaPixel AI not only retains the detail, but actually improves on it...
TL;DR #1 - If you're thinking of buying JPEGtoRAW AI, buy GigaPixel AI instead. For one price, you get better JPEG conversion results
plus an often-quite-capable (though not miracle-working and sometimes frustrating) resize tool.
TL;DR #2 - If have a back-catalogue of JPEG images and own GigaPixel AI, you can use it to produce much better image quality from those JPEGs - including significantly reduced artefacts, "restored" detail, greater tonal adjustment latitude without banding etc.
