Wow! I didn't expect so much feedback and various viewpoints.
Originally posted by photoptimist To do it "right" you would need to pick a specific black and white film and then adjust the red, green, and blue levels to match that film's color response. Orthochromatic B&W films are not sensitive to reds while panchromatic B&W films are.There's also the subtle issue of white balance: do you want a monochrome image of the subject as it was lit or as it would have appeared on B&W film without any color-correcting filters for the type of light source?
> I'm considering what's the right b&w conversion baseline to start from before adjusting parameters: daylight light color temperature for the light source and camera white balance, typical panchromatic b&w film.
Wikipedia (
https://en.wikipedia.org/wiki/HSL_and_HSV) gives some insight on Lightness parameters:
- I (Intensity, arithmetic average of R,G,B),
- V (Value in HSV, largest component of a color),
- L (Lightness in HSL, ),
- Y (Luma), Luma is the weighted average of gamma-corrected R, G, and B, based on their contribution to perceived lightness.
Based on those definitions, I guess that setting de-saturation to zero isn't close to a panchromatic film response because it would would deliver yield L (from HSL) or V (from HSV).
The "monochrome" of Silkypix is defined as the arithmetic average (Intensity, as in Wikipedia page) is close to panchromatic B&W film with flat spectral response, I suppose (not 100% sure)?
The "monochrome2" of Silkypix is defined as perceptual, so it might be some kind of weighted average such as Luma is described in Wikipedia, I would need to test it using a color chart to see how different colors convert into shades of grey.
---------- Post added 03-09-22 at 11:19 ----------
Originally posted by tuco Some film brand examples
I can't explain why, but your b&w film pictures look really good!
---------- Post added 03-09-22 at 11:22 ----------
Originally posted by robgski Don't forget that film photographers would also use colored filters in front of the lens. This would also affect the image. Depending on the subject and colors in a digital image, I often convert my color images to BW by using a colored filter setting.
Yes, correct. I can add color filters to emphasize some image element vs another, after the right r,g,b to b&w conversion starting point.
---------- Post added 03-09-22 at 11:26 ----------
Originally posted by pschlute One thing you can do in Silkypix is to use the Fine Colour Controller in addition to selecting one of the monochrome choices. Increasing the Green, Orange or Yellow colour brightness sliders will replicate the use of a coloured glass filter on the lens at the time of capture
Ah! yes. I know about the monochrome controller in SPD, but I forgot to also consider the default b&w conversion via the controller without any color filter applied. I need to compare the default b&w look from the controller to "monochrome" and "monochrome2".
