Show Printable Version 11 Likes Search this Thread
09-12-2022, 10:59 AM   #1
ChristianRock's Avatar
The ART Raw Developer Thread (RawTherapee fork)
So apparently I'm not the only one annoyed at how RawTherapee was basically abandoned... one developer (agriggio) was not happy with the direction of the project so he created a "fork" based on the fact that this code is all GNU Open Source, and released ART. It's based on all the RawTherapee modules, with some added (yay! Finally local edits and spot removal) and some taken out (mostly the Wavelets that I didn't use anyway).
Things seem to be a bit more logically laid out. Will I like it? Time will tell. I do miss having a dedicated saturation slide but time will tell (maybe they have been moved and I haven't found them yet?).
The page with an option to download is agriggio / ART / wiki / Home ? Bitbucket
And of course, it is as free and open-sourced as RawTherapee.
09-12-2022, 11:33 AM - 1 Like   #2
QuoteOriginally posted by ChristianRock Quote
Things seem to be a bit more logically laid out. Will I like it? Time will tell. I do miss having dedicated contrast and saturation slides but time will tell (maybe they have been moved and I haven't found them yet?).
Art was started long ago, way before the current lag in release. It's a nice RT alternative, simpler and with a slightly different toolset and mindset.
I think the dev wanted to break backward compatibility which RT wouldn't do. I think it probably one of the software worlds forks with the best relationship with the parent software devs. I use dev versions of RT so I've never been impacted by the lack of releases nor have i experienced a single crash (on linux). I tried ART when it was new but never really felt the urge to leave RT
I do think it's a better alternative for a lot of users.
09-12-2022, 11:54 AM   #3
Mooncatt's Avatar
I tried Art, but back to regular RT. If I was forced to use it, I could likely adapt, but why bother if I prefer the regular RT.
09-12-2022, 03:52 PM   #4
I have a windows computer, so I can't run builds.
I thought ART wasn't that old, but I stand corrected. The main issue I have with it at the moment is that it's slower than RT. I'll have to see if in my workflow it's faster to use RT + external editing for what RT misses compared with ART, or if using ART will be faster. Interestingly, ART is faster to save files but RT is faster to edit them. At least that's my initial finding.
I think for a beginner, ART might be better as I find that it's better laid out.
09-12-2022, 08:28 PM - 1 Like   #5
Rawtherapee is not dead:
RawTherapee - RawTherapee 5.9 (WIP) and Project Updates
You easily can download nightly builds.
Release Automated Builds · Beep6581/RawTherapee · GitHub
This includes Linux, Mac, and Windows builds.
These builds are very stable.
09-13-2022, 06:07 AM   #6
QuoteOriginally posted by bwgv001 Quote
Thank you for that! I installed the latest Windows build (14 days ago) and will be testing it. If it works well I'll ditch ART, because ART just seems to be a bit slower to process. But it could be my computer just having too much stuff open... I use it for work as well.
Edit: first impressions of this development build are not positive. it crashes just by doing basic things like opening a new folder. Or opening a file. I know I only have 8GB of memory on this computer but the old 5.8 release has been running very smoothly so I'm very surprised at how bad this new build is looking...
09-13-2022, 12:58 PM   #7
8gb of memory is not the issue. I've basically never had a crash with rt-dev so I'm surprised you're struggling. Being on linux may help but I used RT dev at work on windows without issues as well. Strange.
09-13-2022, 02:35 PM   #8
QuoteOriginally posted by house Quote
Yeah I haven't had issues with my regular version of RT in a while. After crashing a few times I was able to get into that folder and now that the pictures are loaded, I seem to be able to edit them normally. But I only edited a few this morning, as I do have to work
09-13-2022, 07:05 PM   #9
As I mentioned before. For me RT runs just fine. I use it on windows 11
09-14-2022, 09:38 AM   #10
MossyRocks's Avatar
I have really taken to RT as I have used it more and the wavelet features are among my most used. If it had spot correction and local edits (as well as the ability to do multiple graduated nd filters) it would eliminate a lot of the reason I go outside of it for normal photo editing.
09-14-2022, 09:48 AM   #11
QuoteOriginally posted by MossyRocks Quote
RT has spot removal and local edits.
You need to run a dev build, that's what the people making the software suggest. I've been running them for a *very* long time with minor issues. The lack of a new full release is an unfortunate side effect of one individuals lack of time. The person responsible for doing releases . The software itself is good.
https://discuss.pixls.us/t/direct-download-links-to-the-latest-rawtherapee-d...-version/29806
09-14-2022, 09:59 AM   #12
The development builds in the link that @bwgv001 posted have this. I'm using the newest Win64 build right now. I had it lock on me the first few times I used it but after a computer reboot it seems to work better.
ART also has this, but not the wavelets... and unfortunately it's a bit slower. And some stuff doesn't work properly. This morning I tried to edit a picture and was happy with it until I wanted to crop it and the crop simply did not work. I switched over to RT and it worked perfectly.
09-15-2022, 09:15 AM   #13
MossyRocks's Avatar
Good to know, so at some point it will appear. As much of a tech person as I am having local edits in RT isn't a big issue and I would rather tinker with other things than play around with software issues and configuration in my free time as I do that for my job. So since I can do those things in other software I will just do that for now as it is the path of least resistance.
09-15-2022, 10:12 AM   #14
The Squirrel Mafia's Avatar
I tried this a while ago. It's a bit more simpler, but I still prefer RawTherapee overall. I guess I'm used to it now. I've been hacking away on it for the past 8 years now & have pretty much figured out what few settings I need to change to get very good results out of it.
I've gotten to a point where I'm splitting hairs in terms of noise reduction & fine detail. I'd basically would have to use something like DxO PRIME to get slightly "better" results. I say "better" 'cause like always, you give up something for something else.
09-15-2022, 10:52 AM   #15
QuoteOriginally posted by The Squirrel Mafia Quote
So are you using one of the newer builds? I'm waiting on a new dev build to be created and I'll download that and see if that solves my crashing issues, and my intention is to use that and explore the spot removal and local edits functionality. I don't think I'll ever have to use anything else now
Honestly, I've been pretty happy with the noise reduction in RT. I don't have experience in many other softwares, but I can easily and quickly get better results than I did in darktable, for example.
So yeah it's probably splitting hairs
art, art raw developer, developer, photography, photoshop, rawtherapee, time
Do you know ART? ART is a fork of RawTherapee. Simon K Digital Processing, Software, and Printing 6 05-12-2021 11:06 PM
RAW files. What should I use to develop them RawTherapee, Darktable or ......? jonthechippy Digital Processing, Software, and Printing 33 01-16-2018 02:26 PM
Raw Processing workflow; Silkypix AND Rawtherapee? Surnia Digital Processing, Software, and Printing 5 06-02-2016 07:30 AM
Raw Converter - Iridient Developer vs PhotoNinja vs Adobe Camera Raw jeanpierre Pentax K-3 & K-3 II 12 08-28-2014 05:16 AM
K7 RAW conversion with Rawtherapee Workingdog Digital Processing, Software, and Printing 5 02-01-2010 12:16 PM
All times are GMT -7. The time now is 01:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
