I'm experimenting with the new PL6 and the K-3 mark 3. Since I got the camera I was under the impression that the DeepPrime NR did not do as good a job as on my older cameras.
With the new XD variant I think that there is some evidence that support (that is, I guess, fine-tuning of the model for this camera model) could better.
I will post some examples from an ISO12800 test image. It was taken in "bad" light, but it is representative of the general impression I have in the range of about ISO3200+ to ISO12800+.
Up to ISO1600, perhaps 3200 both DeepPrime and XD seem to do a good job and behave "as intended" (i.e. similarly to other cameras).
This is shot with a Fuji XF10, 24MP APS-C sensor (non X-trans). Images are named with a suffix contaning the settings, the first number is the master (luminance) slider, if there is a second number I refer to the "noise model" slider that is new in DPL6.
As you can see at the default luminance of 40, DeepPrimeXD produces equal or slightly less grain in the blurred areas with no artifacts, and preserves even more detail.
And what's more, there is a
strong dependence of the residual noise on the luminance value, from 0 to 100 (last two pictures) I am clearly exploring the trade-off between detail preservation and removal of grain.
On the contrary with the K-3iii at high iso at L40 XD produces way more grain in the out-of-focus areas, and there is
almost no difference in going from 0 to 100 with the luminance slider.
This is a general behavior that I have observed at high-iso and is not strictly picture-dependent (this test shot is rather crappy).
Using the new "noise model" slider with negative values I can obtain results similar to DeepPrime (last picture) but more often than not this introduces an unnatural look in the out-of-focus areas and does not significantly improve detail retention with respect to DeepPrime.
Even keeping the "noise model" slider at negative values, there is very little sensitivity to the "luminance" slider for DeepPrimeXD. This is unlike the other cameras that I have tried.
On the positive side, at lower ISO this new parameter seems to work well and often allows to find a better tradeoff with respect to DP. Furthermore at lower (say <= 1600) ISO, also the sort of inability to remove grain in the blurred areas is not there, it seems to work as intended and really improve (albeit slightly) on DeepPrime.
Any thoughts ? Has anybody found the same issue ?
