Originally posted by kypfer My experience with these sort of symptoms is that DCU "over-reacts" on occasion, applying excessive noise reduction from the start, thereby causing blurring/smearing and/or bad colours in some areas.
This doesn't just happen with "older" cameras, like the *istD models, but at least one instance when I was "pushing the boundaries" with my K-5 and an infra-red filter.
I will emphasise at this point that this is not "usual" behaviour, but sometimes seen with, if not "poorly" exposed originals, certainly images that might be considered to need at least some noise reduction … high ISO, low light levels etc.
So, first check the Noise Reduction tab in DCU, disable anything that is set (making notes if necessary), see what the differences are and then re-apply the various sliders to suit your requirements.
This behaviour may or may not be "by design", I certainly consider it to be less than optimal, but it happens so rarely and it's so easy to remedy I simply live with it
Good luck
OK thank you! In the example that follows I turned off the Spurious color signal reduction; none of the boxes are checked for Noise Reduction. (Highlight Adjustment is applied, compensation 50.)
Originally posted by Kobayashi.K Many camera's have a quality range of 1..3 stars (among them K3-III), while DCU has a range of 1..4 stars when the JPEG is exported. This could mean two things: DCU produces higher quality JPEG's, or the maximum quality (minimum compression) is the same but the total range is subdivided differently.
So I think, to avoid uncertainties, the best test is to compare the embedded JPEG's with the JPEG's saved in-camera with RAW+, for all the possible qualities.
Doing this in a quick test shows that the file size of the embedded JPEG is virtually equal to the one-star (*) JPEG saved in-camera (K3-III).
Besides file size (compression) there might be other settings in the embedded JPEG that are changed, which can also be checked in DCU, and there may be differences between PEF and DNG.
In my test the RAW's were saved as PEF and the JPEG's as Custom image 'Flat'. The embedded JPEG's were saved from DCU by selecting the Browser tab, selecting the RAW, and use menu 'Extract JPEG' with the right mouse button.
Good point about the JPEG quality, but I don't think that's it. I took a JPG with *** quality immediately after (no RAW+ on my camera, as far as I know) and I don't see a difference. I could post it if you want. I think that whatever I am seeing makes a bigger difference than the JPEG quality difference. I didn't know you can get the embedded JPG from DCU, thanks for that!
Originally posted by acoufap Different camera models not only mostly use different sensors but also different algorithms to develop the jpgs based on a specified color mode (natural, bright...).
I don't think that DCU uses camera specific developing algorithms, i.e. for every camera model / color mode the algorithms of these different camera models.
So to me it seams pretty clear that there will be recognisable differences between the camera generated jpgs and the ones generated by DCU.
When a raw converter changes the behaviour of raw development tools with newer versions, then you will often see differences from the new image rendering compared to the rendering of the older version - even if you don't change any parameters.
Ah, thanks!
So here, from a new shot I took today, are the output from DCU and the embedded JPG. (In that order, I think; the DCU is 327.1 KB and extracted is 342.5 KB. Sorry, not sure how to label them. Both attachments are apparently reduced in file size from what they are on my computer.) In the camera, Saturation, Contrast, and Sharpness are all set to 0. When I load the file into Laboratory, DCU tells me it is using in-camera settings (I think; the Camera setting icon is greyed out) and also shows Contrast and Sharpness one tick to the right of center (not exactly sure why they aren't 0, but OK). The other sliders on the Custom Image page are in the center. The Image Tone was set to Bright in the camera, and it looks to me like the setting in DCU for Image Finishing is Bright. White Balance set to camera setting. Everything in Exposure/Tone is 0 or off.
I am not sure whether it is possible to see the relevant difference between the pictures here, but I can definitely see it when I go back and forth between them in Irfanview on my computer. I am wondering, what are they (the camera and DCU) doing differently, what correction?
Thank you!
---------- Post added 01-23-23 at 04:29 PM ----------
Originally posted by pschlute Embedded jpeg is produced by the camera (from raw). DCU jpeg (from raw) is produced by different software.
I fail to see the point in trying to compare one with the other. if you use raw files you should process them to give you the output you want.
Yes indeed, good point; what prompted the question is this. I was reading, in the forum, discussion about the relative merits of sticking with the jpegs that come straight out of the camera vs. working with RAW files. Some say that Pentax does a pretty good job with JPG. So, is there a way to have the camera produce the RAW file, but also to know what it would have produced had it been set on JPG (when there is no RAW+ on the camera)? Some posts on the forum, going back a few years, suggest that one can either look at the embedded JPG or the DCU output when no parameters are changed, and that they would give the same result. But I don't see how they have the same result. So, if I want to know what the JPG would have looked like (while still choosing RAW), would it be the embedded JPG? Is the embedded JPG identical, in all respects, to what the camera would have produced on the JPG (highest quality) setting? Thanks.
