Originally posted by UncleVanya First, thank you. I tried the program and I was lost. I’ll look again. How do I change the interface to not be a washed out gray color. It’s really hard to read.[COLOR="Silver"]
OK, you can get to the 'Preferences' by clicking on the cog wheel icon when in Lightable mode.
'General' in the preferences allows you to select the theme.
There is a quite extensive manual on line.
[Edit] A late thought, you should be able to convert to a mono tiff using dcraw, I think the command 'dcraw -D -T -4' should give you a 16 bit tiff that you can use anywhere
[Edit #2] Apologies...'dcraw -d -T -4 fred.DNG' is more appropriate I think...fred.DNG being your input image, and the resulting image should be fred.TIFF.
To get help on dcraw commands, just enter 'dcraw' on the command line in a console or terminal.
Cheers,
Terry
