Originally posted by NicholasN HG,
How much does it cost to have them framed like that?
Not too much! The frames cost $20-25 (16x20). They are aluminum and very easy to open, an important attribute if using them like I do. I actually change the pictures on a semi-regular basis, they have colour prints in them at the moment. They have std glass. I'm not keen on the non-reflective glass as it seems to cut contrast. Depends on your viewing area as reflections on std glass are worse than non-reflective glass IMO. Paying the electrician to install the lights was about $250 if I recall correctly.
I cut the mat's myself. A 32x40" sheet is usually about $15. You can also get metric sizes but you need to match your frames to the mat board to ensure you get 4 mat's out of one board, otherwise you end up with bits that aren't big enough as the metric version is smaller by a few mm! Once a year my camera club does a bulk buy for our exhibition and gets them for $10 a sheet, so $2.50 a mat
To cut the mat I use a Dexter (I think that's the brand) mat cutter and "Adap-a-Rule" ruler. This thing has a channel that the mat cutter runs down, thus making sure you don't wander away from it, which can happen when using a steel ruler as a guide. I think it was about $100 a few years ago. I use a box cutter and std steel rule as a guide for cutting the big board into smaller pieces. You can use the cut outs as mat's for smaller frames as well.
Another hint to easy mat cutting is to use another piece of mat board under the piece you're cutting so the cutter blade has something to cut through easy. Under that I use a "self-healing" mat to protect the kitchen bench... and avoid the wrath of the Mrs!
Nige.
