03-25-2009, 09:58 PM   #16
Canada_Rockies's Avatar
Elements 6 Auto Quick Fix - 5 seconds
I saved your image, opened PS Elements 6, clicked on [Auto Fix] and saved the file. Here is the result.
03-26-2009, 06:10 PM   #17
mask each section and alter using levels. Rough job in Elements 2
03-26-2009, 07:52 PM   #18
You could try dodging the tree. I just happened to have my Elements 4 book next to my head.
1-Go to the Layers palette & select "new layer" from clicking on the (more) button
2-In the "new layer" dialog box, change the mode to Overlay, and then click on the check box next to "fill with overlay-neutral color (50% gray)". This'll create a new layer over the picture of Neutral gray color, but because of the mode selected, it won't actually turn your picture grayish.
3-Select the brush tool and set up the options for it so it's medium sized & soft-edged. Make the Opacity 30%.
4-In the colors box in the bottom of the toolkit, make sure the foreground color is white. Select the gray layer and start painting white over where ya want things to lighten up.
I hope I explained that right. Here's what I got after fooling with it fer a bit. I didn't dodge everything to make it more obvious.
03-26-2009, 08:37 PM   #19
Ok, since everybody else is having a go, here is my attempt:
2 minute job in GIMP, using the tone mapping plugin and some unsharp mask. I realize that this is a bit overdone, just wanted to show what's possible with free software
elements, photo, photography, photoshop
Picasa for photo processing fekish Digital Processing, Software, and Printing 19 12-09-2010 02:36 AM
Photo Processing Software? NecroticSoldier Troubleshooting and Beginner Help 22 03-30-2010 10:18 AM
online digital photo processing obxeye Troubleshooting and Beginner Help 2 10-17-2009 01:42 PM
best photo processing venues?? dcmsox2004 Digital Processing, Software, and Printing 6 05-03-2009 08:07 AM
Advice on Photo Processing channeler Digital Processing, Software, and Printing 11 07-06-2007 02:26 AM
All times are GMT -7. The time now is 10:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
