Originally posted by dylansalt All the above posts leads me to the conclusion that the "sharpening" process for digital is the hardest, most frustrating, time consuming part of the process;-)
This is the only time I miss the simplicity of when we shot film - good lens & technique=sharp print/slide - easy.
Cheers
Dylan
What's funny is that we used to spend hours and hours researching things like developer technique and film/developer combinations to get 'sharper' images. The psycho-visual component of sharpness has been understood for some time, but with silver the options were limited. Put the best lens you can find on the best camera and tripod you can afford, then expose properly and develop accordingly.
We experimented with still (no agitation) developer - that was tough, but when it worked it was incredible. Overexpose the film a bit, soak it in developer, then pull it out and get it flat (so you didn't have any streaks or variances). In the heavily exposed highlights, the developer would exhaust quickly, and in the less exposed shadows, you'd be effectively pushing them to higher ISO ( only it was ASA back then
) and you'd emphasize the border effect. It was named after a man, but I can't remember his name. It's basically increasing localized contrast near edges. Made them look sharper.
And we did pixel-peep, sorta. And lots of people sneered at that, too! We had 25x aerial focusing scopes, and 50mm lenses on Omega D4 enlargers with condenser heads; rack that thing to the top, focus on the scope, and you could count silver oxide lumps in Plus-X negatives.
I used Technical Pan (ASA25, black and white, on a mylar backing) and developed it with technidol; THAT was a combination that outresolved any lens you can put your hands on, and 5x7s from that 35mm negative had long, smooth tonal scales that looked like medium format.
Those were fun days. But I certainly don't think they were any less technical. Many people had LBA, and we argued about which lens was sharpest, and magazines still did resolution tests, and... well, you get it.
Photo geeks are photo geeks.
