Originally posted by BobG
Thanks for your response. I've noticed this regardless of the sharpening level that is set in camera. Whatever the +/- sharpening setting may have been (or the image tone setting also) the Slideshow resolution is much better than just clicking "View Image" and opening a single file.
Well, whatever sharpening level you have applied in camera, the slide show is presumably adding more still. It would be interesting to compare what the slide show does when you 8don't* have sharpening turned up in camera against what the regular view image does when you have sharpening turned up all the way.
Also, if you haven't tried shooting in Bright mode, you might try that, to see if that gives you more sharpening.
The point being, I would bet that View Image is showing you your image more accurately (as they were shot), but that slide show is adding some processing. If so, the triuck would be to get the actual image to have that same sort of processing applied.
