Originally posted by Marc Sabatella That's looking a it backwards. A image doesn't have dpi nor does it have a size in inches. All it has are pixels. The other two parameters - size and dpi - are determined when you go to print, and are not - cannot *possibly* be - attributes of the images. An images has a certain number number of pixels. It does not *have* a resolution in dpi. That's not misinformation, it's the nature of digital imaging.
So sure, you could say you have an image that is "a 300 dpi file that is set to 4x6 inches" - but that's an extremely roundabout and technically inaccurate way of saying it has 1200x1800 pixels.
Actually it seems to me that an image has a starting size ie 14mp's contained in a 24x16mm frame. So each "pixel" starts off at 6 (2, 5, 9 ect)microns (forgive the sweeping generalities and pretend the software has interpolated each sensel into one "color"). From there you enlarge (shrink) or multiply (divide) to "FIT" the container of your choice at a density of your choice...
As long as uprezing (downrezing) isn't done the "tag" is meaningless until you give it meaning.....
of course an image printed at "native" size would be exactly the size of the sensor minus dead space at an extremely high "ppi" (198 pixels per mm or 5029 ppi)
Roughly... I think.......
Old printer stats.....
Canon's new print head features Micro-Nozzles capable of delivering consistent 2pl droplets with ultimate dot placement and giving a true resolution of 4800 x 1200 dpi. At 10 microns in diameter, the individual nozzles are about 40% smaller than the closest competitor's
