Originally posted by graphicgr8s Changing the dpi/ppi changes the SIZE of the pixels. Not the quantity. Printing at 72 abd 56 inches will yield a low quality output when viewed up close.
Sorry, your definition is sort of confused. You're mixing printing dots with image pixels. But that are two wholly different stories! I have been in the business of both, image acquisition and digital printing, for the last fifteen years and though I sure do make mistakes or do not know everything, I at least get my pixels right... You obviously mean printing dots. But at least with digital printing these do not have a defined final size. First of all the manufacturers don't state values, only ink volumes, not print dot sizes. Secondly during printing these dots get layered and/or dithered to form the final colour dot. The size of that dot is variable as it depends on the saturation and hue of the colour. Conventional printing (offset printing) is ofcourse an entirely different thing and we would talk about lpi and we would need to talk about screen ruling and screen angle.
Image pixels are much easier to understand, though I have never actually seen any statement about their size. I would guess it is a matter of esoterics, as the single pixel ideally is a point = infinitely small. In reality you have a finite number of pixel which you spread out over space as you like. As we can safely assume, that the image formation will not show gaps between the pixels (one difference compared to printing) we could simply divide the image width or height through the number of available pixels to calculate the size of the single pixel.
This is where resolution comes into this play: When the size of the pixel increases beyond the limit, where the single pixel gets visible for the naked eye at usual viewing distances, the quality breaks down. The average eye resolves detail down to just about one arcminute (really trained eyes might be better, down to 30 arcsecs). This is the reason, why generally "normal" printing sizes (for images viewd in a photo album or standard pictures on the wall) require an image resolution of 300dpi. If you have really large prints, which you view from a distance (posters, banners viewed across the stree), you can go down in resolution to perhaps something like 5dpi and the quality will still be adequate.
So, back to your above statement: As you can read out of my longish post above, changing the "size" of a pixel is a necessary consequence of reducing their number, if the overall size of the image (in units of length) stays fixed. You could perhaps devise a algorithm to have the pixel size fixed and would get something like a screen printed image, with lots of white space around each pixel. You could on the other hand preserve resolution and print quality, by simply making the print size smaller, after reducing the number of pixels:
If you reduce an image to 600 x 800 pixels, to make printing of high quality prints impossible, you have the choice to print an image with only 72dpi resolution at a size of 8 x 11 inches. 72 dpi would not look nice. But you could also print an image at 300 dpi, but the size would only be 2 x 2.7 inches - a bit small for most tastes.
Nevertheless many untrained viewers (Auntie and Grandpa) will accept images in most cases happily printed with only 150dpi, because the average viewer will concentrate on the contents and the colour, not so much on edge sharpness or fine tonal differentation. This is the reason, why a simple reduction in pixel numbers might not be a working solution to image protection, because many people would print low res images and would still be happy.
So, I personally think, there are two alternatives for protecting images:
- simply accept that people will print low res images and try to emphasize the advantages of buaing a high res print
- add a watermark of kind to the image
Ben
