Originally posted by expatCanuck - 2GB RAM enough, or should I go to 4GB?
- Will 2 separate hard drives (one for the OS, one for photos) make a noticeable difference?
- Is the AMD Athlon 64 X2 5050e Brisbane 2.6GHz a fast enough CPU?
(I rather like the idea of only drawing 45w) - Do I need a separate video card and, if so, how much RAM should it have?
1. I doubt there's any photo that requires 2+ gb of memory to process in memory, but with memory prices as cheap as they are, go with 4 gb.
2. 2 separate hard drives striped will make a difference when dealing with video, as they'll tend to be several gb in size and the extra throughput will make moving them around faster.
3. I'd recommend quad core and as fast as you're willing to pay for when dealing with video. Video encoding alone takes a heavy toll.
4. A separate video card won't make a difference unless the application(s) you plan on using have specific support for the GPU. And even so, the amount of ram on it isn't usually an issue, but the number of cores/processing units on it and their speeds will affect performance.
