Hello,
I have pretty much edited the guts out of the below image and after changing it over and over again I want to start from scratch with the Original. Well, maybe not from scratch if I can eliminate the problems:
The bottom right section has a slight redness to it, and with the enhancements I've made it had made it even more red but the rest of the image i like.
I've got the DNG image in CS4 but i can't seem to get the look I got in LR as it involves boosting the blue sliders which introduces more red ( and changing the red slider doesn't help )
Is there a easy way I can either fix the edited version Or
Extract the dandelion head from the background and somehow get the same affect.
Also, I've applied a blur to the background using the ' cut' tool to select as closely as possible to the dandelion head, to get rid of noise.
I really want to get this Photo perfect so I can print it on A3 when I get the Epson R1900
Thank You
