"Discovered" podcasts put out by
TPN :: The Digital Photography Show and on one of their episodes, conducted an interview with Scott Kelby. When it comes to Photoshop, Scott knows what he is talking about.
During the interview, he shared the methodology by which he applies sharpening to his images. The biggest problem with sharpening is the "ringing" around edges of high contrast. His method avoids this. (He also shared his unsharp mask parameters. 85,1,4)
What Scott does is convert his RGB images to LAB color. (I'm used to calling this color space "HSI" for "hue", "saturation", and "intensity". LAB and HSI are the same, aren't they?) Anyway, he applies his unsharp mask, or smart sharpen mask to only the "lightness" channel, not the "A" nor "B" channel. What he says you can do is apply the same filter twice in succession without any degradation of the image. Then, he converts back to RGB color space for final output or further processing, if desired.
(Also "discovered" a better way to apply NeatImage noise reduction plug-in. I usually don't use profiles, but instead let the plug-in select a training area. Results are mixed. This time, I processed each LAB channel separately, with pretty good results. The training area selected by the plug-in differed with each LAB channel.)
LAB sharpening method seems to work pretty good. Hard to tell on the image below due to having to size it down for web posting. Pixel peeping on the full-res images really shows how much better LAB filtering is over staying in RGB mode. Whenever I need to sharpen, I'll use LAB color from now on.
Image taken on April 3rd of this year, at just past midnight of a full-sized copy of Michelangelo's David standing in the Piazza della Signoria in front of the Palazzo Vecchio in Firenze, Italia (Florence, Italy).
K10D
DA 21/3.2
P exposure mode
f/3.2
ISO 1000
0.3s (yup, 1/3 of a second, hand held - gotta love that Shake Reduction)
center weighted average metering
no flash
