Originally posted by Wheatfield That's great if all you do in post processing is RAW conversion to a printable file. If that's the case, then just shoot jpeg, the quality difference will be non existent.
What you aren't taking into account is the myriad of other things that get done during post processing: cloning, spotting, applying various filters for improving elements of the image, even basic cropping (Lightroom remembers this last one).
I throw out the final PSD, I've also thrown out 90% of what I do in post.
You're leaving out a huge middle ground - things that go way beyond simple "RAW conversion to a printable file", but can be done within the confines of RAW processing. I'm talking about the things that can be done in ACR - adjustments to exposure, curves, saturation, white balance, noise reduction, sharpening, vibrance, cropping, etc. Those are all areas where shooting RAW make a huge difference - more so, fact, than the things you list (cloning is not something where the limitations of JPEG are particularly problematic). Although to be sure, relatively few RAW processing applications support cloning.
Anyhow, all work done in ACR is saved automatically without the need to convert to another format. So if your workflow is such that most of the processing work you do is doable in ACR (or the equivalent in LR or any other "non-destructive" RAW processing software), then exporting a new version is not necessary in order to save the work you've done.
If on the other hand you regularly edit your image in traditional "bit oriented" editing programs like Photoshop, then indeed, you need to explictly save that work somehow.
Quote: Something else to remember when archiving files is to ask yourself: will this file be readable in 5, 10, 20 years? A manufacturers proprietary raw file is the least likely to be supported
True. Although I don't expect support to disappear overnight. Before installing a version of an application that no longer supports my older files, I'd probably go ahead and convert them with the old version - or perhaps convert to DNG if by then this seems a ticket to better future proofing.
