I do almost all my PP in Camera Raw. I never shoot JPEG - waste of time imo
I usually do the following in Camera Raw in mostly this order:
1. Lens distortion correction
- Correct for chromatic abberation. Blow the image up to 200% and get into the corners where it shows the most and get that fixed. Check centre after adjustment.
- Correct for purple fringing. If there is no purple in the scene, then back off purple saturation as a matter of course.
- Correct for any corner light fall off.
2. Colour balance
- Check histogram and adjust exposure, using Recovery slider (superb tool!) where necessary as not to blow the highlights. If underexposed, use Fill Light to bring detail to shadows.
- Adjust contrast (usually a slight boost) to suit.
- Tweak Clarity slider to bring localised contrast and give impact to image (good for black and white, not so good for flesh tones / skin / portraits).
- Boost saturation very slightly to see effect, keep if attractive.
- Sharpen image.
3. Save image
- Save final image into master TIFF folder.
- Create new folder called TIFF Adjustments.
- Create new folder called JPEG sRGB.
4. Rotate / Align / Crop / Resize
- Load master TIFF into Photoshop and correct for rotation as required.
- Crop as required to frame composition.
- Save into TIFF Adjustments folder.
- Create resized (typicall 1280 pixels wide) sRGB based JPEG for web uploading (Flickr, Facebook etc.).
