Originally posted by edl Thanks for the explanation Gooshin, that makes sense. I'll give the V500 another go at native res (which I'm assuming is 6400dpi) and then downsize it in PS.
What I'd really like is a scanner where you could just feed the negative strip in and it does everything else (setting black and white, dust removal, etc). I bet those are expensive though. Surely it would cost more than my "point & shoot" V500
the Nikon scaners, you could buy a special roll-feeder attachement (like 50 bucks i think extra)
all you would have to do is tell the developing place (or if you do it yourself) is to leave the film un-cut.
you put the whole reel on one end of the scanner, and play around with the settings on the first frame, then hit go. Come back in 30 minutes and you're done. Just make sure your computer doesnt crash, or as a precaution, disable that part where the photo "previews" after its been scanned.
Nikon Scan 4 threw my computer into overdrive after i had like 15 130mb tiff files open, since it is very innefficient as a program.
