Originally posted by rm2 Well, the reason I ask is because I do not have any of my monitors calibrated and yet I see no problem with my images after I process them.
Well, no, of course - because you are processing the images to look good on your uncalibrated monitor. The problem only comes in if soemone else views the images on their monitor. Unless your monitor just *happens* to already be in perfect calibration (which I gather basically never happens), the images *will* look different on someone else's monitor. the issue is whether you are bothered by this or not. If you're happy making the image look its best to *you*, and don't care if they look different to someone else, then as I said, calibration will provide you with no benefit.
Quote: My print results look great too
Again, the issue isn't how "great" they look, it's how closely they match what you see on your monitor. If you hold a print up next to your monitor and don't see any differences that bother you, then great - hold on to that monitor and that printer because they appear to happen to work well together. I'd still expect a different monitor or a different printer to produce different results. Not necessarily worse - just different. If that matters to you, then calibrate. If it doesn't, then don't.
