Originally posted by SuperAkuma Forever is close to 5 minutes. I have lots of layers. The file size is close to 300mb in 16 bit. In 8 bit it is under 100mb.
Sharping is no problem, it is when I use surface blur. The surface blur was set pretty high. I just tested it again, at 16 bit it was about 5 minute to rendure the surface blur filter. At 8 bit, it was instant on the same image.
Hmm, I see what you mean. I just took an image (16 bits per channel), made 5 layers, then ran surafce blur with settings of 51, 134, and CS4 took over 4 minutes to process. Convert the image to 8 bits per channel, and the operation took around 10 seconds. Vista's task manager shows all 4 CPU cores working at nearly 100%.
Maybe test a couple of images at 16 bit and 8 bit, and if you don't discern a difference between the 2, go for 8 bit. Maybe do all operations other than surace blur in 16 bit mode, then switch to 8 bit for surface blur.
